  3. Can SKILL be run in Batch Mode?
  • Subscribers 19
  • Views 4161
mahimag
mahimag over 2 years ago
Allegro X PCB Editor and Allegro X APD provide two different ways of automation: One uses scripts (*.scr) and the other uses SKILL language. Both methods provide a way to store the code that is either recorded or created in a file which will be sourced and ran later.
  • Allegro scripts are stored as .scr files and executed in the Allegro terminal using replay <file path>.scr.
  • SKILL code is stored as .il/.ilinit files and executed in the Allegro terminal using skill load("<file path>.il").
As of today, Allegro allows script automation in batch mode only by calling scripts using the following command in your preferred terminal (batch, bash, cshell, etc.):
allegro -s <path to the allegro script> -nograph <allegro board>
Here, -nograph is an option that prevents the Allegro GUI from displaying. The board is also optional.
Although you cannot directly call SKILL code using this method, you can do it indirectly by creating a simple Allegro script, such as tmp.scr, which would call a SKILL file. Internally, this script would look like the following (as an example):
skill load("script.il")
skill <function name>(<function parameters>)
exit
You then run the script using the following batch command:
allegro -s tmp.scr -nograph
The above command assumes that both files (Allegro script file and SKILL file) are accessible in the same folder and this folder is currently open in the shell terminal.
You must add an explicit exit command, or the tool will not exit, even though it was launched in nograph mode.
Using this method, the flow can be improved in many ways by fully embedding all SKILL code in a .scr file and making use of the skill keyword before each command.
What do you propose? Do you have any other way of executing SKILL in batch mode?
