  3. Wanted to update the Padstack Definition for existing P...
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 1546
Wanted to update the Padstack Definition for existing Padstacks
Hussain Aalim
Hussain Aalim over 2 years ago
Can anyone help me with the skill code to update the Padstack Definition for existing Padstacks as shown below:
Wanted to update these three layers with the size of the Anti Pad and wanted to keep the remaining same.
Thanks in advance
  • SaiPavanl
    SaiPavanl over 2 years ago +1 suggested
    Programmatically, you cannot modify a padstack, as it is read-only. So, you need to copy the pads and then make modifications. The function to copy a pad is shown below. You need to find the layer of the…
  • SaiPavanl
    0 SaiPavanl over 2 years ago
    Programmatically, you cannot modify a padstack, as it is read-only. So, you need to copy the pads and then make modifications. The function to copy a pad is shown below. You need to find the layer of the pad and decide the parameters to copy depending on whether the figureName is FLASH or not. For FLASH, copy the name to ?flash; else, copy inPad ->figureName to figure.
    (procedure copyPad(inPad)
    (let (layer subClassName className)
    layer = parseString(inPad ->layer "/")
    ;printf("layer is %L\n" layer)
    className = car(layer)
    subClassName = cadr(layer)
    size=getPadFigureSize(inPad)
    (if inPad->figureName == "FLASH" then
    newPad = make_axlPadStackPad(?layer subClassName,
    ?type inPad ->type
    ?figureSize size
    ?figure 'FLASH
    ?flash inPad ->flash
    ?offset inPad ->offset
    else
    subClassName,
    ?type inPad ->type,
    ?figureSize size
    ?figure inPad ->figureName
    );if
    newPad
    );let
    );procedure
