  3. Import Logic/Netlist using SKILL
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 4666
Hussain Aalim
Hussain Aalim over 2 years ago
Can anyone help me with scripting the automation of the Import -> Logic/Netlist process?
Thanks in advance!
  • Elecguy
    0 Elecguy over 2 years ago
    Do you require SKILL in the solution? what if you use a regular script (File > script)?
  • Hussain Aalim
    0 Hussain Aalim over 2 years ago in reply to Elecguy
    Elecguy Yes, I want to automate the importing of the netlist/logic using SKILL. A regular script wouldn't be sufficient, as I need to integrate the importing of netlist/logic directly into my existing code, which requires a more robust solution.
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    Hi Hussain Aalim,
    You can refer this code,
    Out_File = outfile("./netlist_n.txt" "w")
    fprintf(Out_File "$PACKAGES\n")
    refdes = enter_sym_name
    if(axlDBFindByName('refdes refdes) == nil then
    fprintf(Out_File "%s ! %s ; %s\n" refdes refdes refdes)
    fprintf(Out_File "$NETS\n")
    foreach(row netin_list
    fprintf(Out_File "%s\n" row)
    fprintf(Out_File "$END\n")
    close(Out_File)
    axlRunBatchDBProgram("netin" "netin -$ -g -y 1 netlist_n %s" ?startMsg "Logic Import" ?noProgress t ?logfile "netin" ?reloadDB t)
    HoangKhoi.
  • PP202506235415
    0 PP202506235415 over 1 year ago
    I am facing this problem too.
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago in reply to PP202506235415
    Hi PP,
    Could you please let me know what issues you're experiencing?
    Best regards,
    Hoang Khoi
