  3. Place Via Array Boundary
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 4488
karthikeyank
karthikeyank over 2 years ago
Hi All,
I want to do some operations like Place->Via Array->Boundary, I have additional requirements. I don't know how to place via in ODD and ARC Segments. Can anyone plz help me out.
Program:
foreach(ClineDtlp ClineDt
foreach(ClineSegDtlp ClineDtlp->segments
ObVal = ClineSegDtlp->objType
XpointF = xCoord(car(ClineSegDtlp->startEnd))
YpointF = yCoord(car(ClineSegDtlp->startEnd))
XpointS = xCoord(cadr(ClineSegDtlp->startEnd))
YpointS = yCoord(cadr(ClineSegDtlp->startEnd))
println(ObVal)
if(ObVal == "line" then
LnVal = sprintf(nil "%s", ClineSegDtlp->lineType)
if(LnVal == "vertical" then
FirstVal = axlDBGetLength(ClineSegDtlp)
println(FirstVal)
FirstVal = round(FirstVal)
PassVal = FirstVal / 30
PassStr = sprintf(nil "%d", PassVal)
PassPrseStr = atoi(nth(0 parseString(PassStr "-")))
println(PassPrseStr)
if(YpointF > YpointS then
for(i 1 PassPrseStr
myvia = axlDBCreateVia("DUMMY_20MIL", XpointF + 50:YpointF, nil, nil, 0.0, nil)
YpointF = YpointF - 30
else
for(i 1 PassPrseStr
myvia = axlDBCreateVia("DUMMY_20MIL", XpointF + 50:YpointS, nil, nil, 0.0, nil)
YpointS = YpointS - 30
else
if(LnVal == "horizontal" then
;Code
else
if(LnVal == "odd" then
;Code
else
if(ObVal == "arc" then
;Code
Image:
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago
    Hi karthikeyank!
    You can try this code. It work on version 17.2 or latest
    axlCmdRegister("div_cline" 'div_cline)
    (defun div_cline ()
    axlClearSelSet()
    axlSetFindFilter(?enabled '(noall CLINES NAMEFORM) ?onButtons '(noall ALL))
    axlSingleSelectPoint()
    cline = car(axlGetSelSet())
    axlClearSelSet()
    if(cline != nil then
    pitch_via_via = axlDBGetLength(cline) * 0.1 ; 10% total of the cline length
    loop = t
    vias = setof(e axlDBGetConnect(cline t) e->objType == "via" )
    if(length(vias) == 2 then
    point = car(vias)->xy
    if(member(point car(cline->segments)->startEnd) == nil then
    point = cadr(vias)->xy
    point_list = list(point)
    curr_seg = nil
    while(loop == t
    if(curr_seg == nil then
    tmp = cline->segments
    curr_seg = car(tmp)
    else
    tmp = member(curr_seg cline->segments)
    tmp_point = nil
    while(length(tmp) > 0
    seg = car(tmp)
    st_seg = seg->startEnd
    if(seg->objType == "arc" then
    cir_line = axlGeoCircleCircleInt(point pitch_via_via seg->xy seg->radius)
    else
    cir_line = axlGeoCircleLineInt2(car(st_seg) cadr(st_seg) point pitch_via_via)
    if(cir_line != nil then
    seg_poly = car(axlPolyFromDB(seg ?endCapType 'ROUND))
    cir_line = setof(e cir_line axlGeoPointInShape(e seg_poly nil) == t)
    cir_line = setof(e cir_line member(e point_list) == nil && e != point && setof(e2 point_list axlDistance(e e2) < seg->width * 0.5) == nil )
    if(length(cir_line) == 1 then
    tmp_point = car(cir_line)
    curr_seg = seg
    tmp = nil
    else
    if(length(cir_line) == 2 then
    dis1 = axlDistance(car(cir_line) point)
    dis2 = axlDistance(cadr(cir_line) point)
    if(dis1 < dis2 then tmp_point = cadr(cir_line))
    curr_seg = seg
    tmp = nil
    tmp = cdr(tmp)
    if(tmp_point != nil then
    point = tmp_point
    point_list = cons(point point_list)
    d_actual = car(cline->segments)->width
    d = axlMXYAdd( 0:d_actual point)
    r_path = axlMakeDynamicsPath(list(list(d d 0.0 point d_actual t) list(d d) ) )
    poly = car(axlPolyFromDB(r_path ?endCapType 'ROUND))
    axlDBCreateShape(poly t "ANTI ETCH/ALL" nil)
    axlVisibleLayer("ANTI ETCH/ALL" t)
    else
    loop = nil
    HoangKhoi.
  • karthikeyank
    0 karthikeyank over 2 years ago in reply to Hoangkhoipcb
    Hi HoangKhoi,
    Thank you for your reply actually I'm using 16.6 version so any other ways to do by skill program, if yes can you update the program that would be so helpful.
    Karthi
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago in reply to karthikeyank
    Hi karthikeyank!
    it work on 16.6 version or latest.
    (defun div_cline ()
    axlClearSelSet()
    axlClearSelSet()
    loop = t
    curr_seg = nil
    while(loop == t
    curr_seg = car(tmp)
    else
    tmp_point = nil
    seg = car(tmp)
    cir_line = PointsCirCir(point pitch_via_via seg->xy seg->radius)
    else
    cir_line = PoinstLineCircle(car(st_seg) cadr(st_seg) point pitch_via_via)
    curr_seg = seg
    tmp = nil
    else
    curr_seg = seg
    tmp = nil
    tmp = cdr(tmp)
    point = tmp_point
    else
    loop = nil
    point_list = unique(point_list)
    foreach(point point_list
    axlShell("div_cline")
    printf("Last Update: 07/11/2024 -Version 1.0\n")
    (defun PointsCirCir (point1, r1, point2, r2)
    let((point_list2)
    prog((point_list2)
    x1 = xCoord(point1)
    y1 = yCoord(point1)
    x2 = xCoord(point2)
    y2 = yCoord(point2)
    d = sqrt((x2 - x1) * (x2 - x1) + (y2 - y1) * (y2 - y1))
    if(d > r1 + r2 || d < abs(r1 - r2) || d == 0 then
    return(nil)
    else
    a = (r1 * r1 - r2 * r2 + d * d) / (2 * d)
    px = x1 + a * (x2 - x1) / d
    py = y1 + a * (y2 - y1) / d
    h = sqrt(r1 * r1 - a * a)
    p1 = px + h * (y2 - y1) / d : py - h * (x2 - x1) / d
    point_list2 = cons(p1 point_list2)
    if(d != r1 + r2 && d != abs(r1 - r2) then
    p2 = px - h * (y2 - y1) / d : py + h * (x2 - x1) / d
    point_list2 = cons(p2 point_list2)
    return(point_list2)
    (defun PoinstLineCircle (point1, point2, center, radius)
    let((point_list2)
    prog((point_list2)
    dx = xCoord(point2) - xCoord(point1)
    dy = yCoord(point2) - yCoord(point1)
    A = dx * dx + dy * dy
    B = 2 * (dx * (xCoord(point1) - xCoord(center)) + dy * (yCoord(point1) - yCoord(center)))
    C = (xCoord(point1) - xCoord(center)) * (xCoord(point1) - xCoord(center)) + (yCoord(point1) - yCoord(center)) * (yCoord(point1) - yCoord(center)) - radius * radius
    delta = B * B - 4 * A * C
    if(delta > 0 then
    t1 = (-B + sqrt(delta)) / (2 * A)
    t2 = (-B - sqrt(delta)) / (2 * A)
    if(t1 >= 0 && t1 <= 1 then
    point_list2 = cons(xCoord(point1) + t1 * dx : yCoord(point1) + t1 * dy point_list2)
    if(t2 >= 0 && t2 <= 1 then
    point_list2 = cons(xCoord(point1) + t2 * dx : yCoord(point1) + t2 * dy point_list2)
    return(point_list2)
    HoangKhoi.
  • karthikeyank
    Hi HoangKhoi,
    Thanks a lot. Appreciate your support It works well.
  • zpofrp
    0 zpofrp 5 months ago in reply to Hoangkhoipcb
    Hi HoangKho and karthikeyank,
    Could you share the skill to place via on both sides of cline.
