  3. How to change the DFA_DEV_CLASS for individual symbol that...
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 1826
How to change the DFA_DEV_CLASS for individual symbol that shared same COMPONENT TYPE
ENEGUE
ENEGUE over 1 year ago
Hello Everyone,
Scenario, i got two 0402 component sharing same symbol with two different supplier, one of them with higher package/footprint tolerance. Theoretically, designer is advice to space out the component with Hi-Tolerance.
Hence i try to cater this by using skill to change the symbol definition properties DFA_DEV_CLASS then use DFA table to catch the DRC whenever designer place the Hi-Tolerance part too close with one another.
I managed to change the DFA_DEV_CLASS using the axlDBAddProp->  axlDBAddProp(same_sym_pn->symbol->definition '("DFA_DEV_CLASS" "CHIP_0402_HTOL")), but this method will apply to all the same symbol name.
Is there a way only change individual symbol DFA_DEV_CLASS properties?
Any other suggestion is welcome too.=)
Eugene
  • digital1
    0 digital1 over 1 year ago
    if you use ipc names for your footprint then you wouldnt have this problem ipc names are resc0402_height for resistors or capc0402_height for capacitors where height is the height of the component
    chip_0402 is not a recognised name and will cause problems for you in the future as is what is happening now
    • Vote Up -2 Vote Down
  • ENEGUE
    0 ENEGUE over 1 year ago in reply to digital1
    Thanks for your input, possible to elaborate more? current plan is to use DFA to catch the distance between H-Tolerance component with others. As much as i know DFA table is refer to component DFA_DEV_CLASS, may i know how does IPC name able to help in this case?
    Eugene
  • K3PO
    0 K3PO over 1 year ago in reply to digital1
    Some organizations have their own naming scheme so using IPC guidelines isn't always possible. I have essentially the same question, how to modify/change the DFA class for a symbol in a design (or create a local symbol and modify that)?
  • K3PO
    It doesn't appear that you can overload the symbol property from a design.brd as it is applied at the symbol level.
    One workaround to this might be to make a local library and create a <symbol_name>_DFA_DEV_CLASS symbol and use it as an alternate.
