  3. Set shape transparency for pdf_out export via skill
  • State Suggested Answer
  • Answers 1
  • Subscribers 23
  • Views 4016
SOT23
SOT23 over 2 years ago
Hello.
I am writing a SKILL script to export a PDF of the gerber files with correct parameters. I am trying to set the transparency level of the filled shapes to 0 using axlSetVariable() so that the gerber shapes are black but it doesn't work.
Here is the code :
; get the current shape transparency setting
shapeTransparency = axlGetVariable("pdf_filled_shape_transparency")
println(shapeTransparency)
; set transparency to 0
println(axlSetVariable("pdf_filled_shape_transparency" 0))
; print PDFs
sprintf(cmd, "pdf_out BOARD_NAME.brd -o 1 -f ARTWORK_NAME -s -B -a -p -h -c gerberPDF.conf")
axlRunBatchDBProgram("pdfout" cmd ?noUnload t )
; set back transparency to previous value
axlSetVariable("pdf_filled_shape_transparency" shapeTransparency)
I can read the current shape transparency setting. However, each time I println it through the program, I always get the same value. It seems like axlSetVariable() doesn't work here. I have tried using axlSetVariableFile() with the same results.
Anyone has an idea what might be wrong here ?
Thank you!
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
    I would change:
    to
  • SOT23
    0 SOT23 over 1 year ago in reply to DavidJHutchins
    Hello, that is what I initially did, and it does not work. I used println to print the returned value of the function axlSetVariable, which is "t" here.
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to SOT23
    I am not sure if setting the variable value in Allegro is going to be seen when you run the export using axlRunBatchDBProgram()
    since I am not sure the sub-process inherits the current sessions variables...
  • ABIKRISHNA
    0 ABIKRISHNA over 1 year ago
    ==> In this code it shows nil in shapeTransparency value.
    ==>In this code only you set the pdf_filled_shape_transparency value to 0. So it gives output as shapeTransparency nil
    ; print PDFs
    In this you are settting pdf_filled_shape_transparency=>shapeTransparency. We already shapeTransparency is updated as nil. So it always gives nil only.
    Below I changed the code Kindly test it.
    axlSetVariable("pdf_filled_shape_transparency" 1)
    before_shapeTransparency = axlGetVariable("pdf_filled_shape_transparency")
    println(before_shapeTransparency)
    ; print PDFs
    axlSetVariable("pdf_filled_shape_transparency" before_shapeTransparency)
  • Ulf K
    0 Ulf K over 1 year ago in reply to ABIKRISHNA
    ...Borrowing the thread...
    Intended for Cadence staff: Suggesting a product enhancement.  Not a priority but...
    When creating (service) documentation, it is often helpful not only to show the Assembly layer with component outlines but it would also be of great help if the top layer could be presented in some level of gray-scale as well - provided of course that the top layer apart from the solder pads is not a solid ground plane.
    In older service manuals, this was often accomplished using manual labor and photo-copying. If creating service documentation in color that would be one thing, but solid filled shapes are not optimum. Same thing with traces where (my favorite...) skeletal view of pads and traces could be implemented as well.
    Using OrCAD Professional, maybe these features are available in higher (allegro) license levels.
    If they are, then sorry for the noise.
