  3. filtered IDF out
  • State Verified Answer
  • Subscribers 19
  • Views 1579
filtered IDF out
Mabr86
Mabr86 over 1 year ago
I want to export ptc-data using the axlRunBatchDBProgram function. However, certain objects (e.g. Route Keepout, Via Keepout,...) should be filtered out before the export. Is there a possibility for this?
  • mahimag
    +1 mahimag over 1 year ago
    Hi Mabr86 , you can use [-c <config>] Configuration File option "Name of the file to use to filter the specified parameters from the resultant IDF file" with axlRunBatchDBProgram .
    The full valid argument list for IDF out is
    Command line arguments for idf_out is as below:
    idf_out <brd> [-doVbhs] [-c <config>]
    OPTIONAL ARGUMENTS
    [-d] Third party file format.
    Valid Arguments: IDF, PTC, SDRC
    Default: IDF
    [-o] Output file name. Name of the resultant IDF files.
    Default: <design_name>.bdf, <design_name>.ldf
    [-V] IDF Version.
    Valid Arguments: 2.0, 3.0
    Default: 2.0
    [-b] Design Version.
    Valid Arguments: user specified integer.
    Default: 1
    [-s] System ID.
    Valid Arguments: user specified string.
    On UNIX spaces in this string is not supported.
    Default: ""
    [-h] Default height. Applies this value to all package symbols
    without a specified package height.
    Valid Arguments: a floating point value consistent with the
    original design units.
    Default: 0.0
    [-c <config>] Configuration File. Name of the file to use to
    filter the specified parameters from the resultant IDF file.
    REQUIRED ARGUMENTS:
    <brd> Name of the design file.
    EXAMPLE:
    idf_out -d IDF -o out_test -s ACME_CAD_2.0 -b 2.0 -h 20 -V 3.0 test
  • Mabr86
    0 Mabr86 over 1 year ago in reply to mahimag
    Thank you!
