  3. Expand/Contract -> Shape Boundary Segments
  • Replies 7
  • Subscribers 22
  • Views 5426
SambaKantipudi
SambaKantipudi over 1 year ago
Hello All,
I would like to select Cutout Shape(s) and then create a new shape on "ROUTE KEEPOUT/ALL", with an expansion value of 0.4mm. Now I would like to contract the horizontal line segments/paths of the newly created "ROUTE KEEPOUT/ALL" excluding the arc segments with -0.15mm.
Unfortunately, I cannot attach an image to better illustrate.
I would like to achieve the above result using Skill.
Requesting someone for help.
Thanks in advance
Samba
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to DavidJHutchins
    After looking at the image you provided, below is how I would attempt to code this:
    First, create 2 temp layers ( temp_lines & temp_arcs )
    Then use 'Shape>Decompose Shape' to expand the 'board geometry/cutout' shape by 0.15mm to temp_lines
    Then delete any 'arc' data on temp_lines
    Then use 'Shape>Decompose Shape' to expand the 'board geometry/cutout' shape by 0.40mm to temp_arcs
    Then delete any 'line' data on temp_arcs
    Then for each arc endpoint, find the closest line endpoint by searching within the arc radius for endpoints & create a line segment between the arc & line endpoints on temp_arcs
    Finally construct the 'route keepout/all' shape from the segments on temp_arcs
    Post-process by deleting everything on temp_lines & temp_arcs and deleting those layers
  • DE202408202727
    DE202408202727 over 1 year ago in reply to DavidJHutchins
    This was my solution for him. I would prefer to use maths than do it with polygons but this was easier:
    poly = car(axlPolyFromDB(cutoutDBID))
    routePoly = car(axlPolyExpand(poly, 0.4, 'ALL_ARC)); Expand polygon by 0.4
    lineSegments = setof(seg, cutoutDBID ->segments, seg ->objType == "line")
    end1Pt1 = car(car(lineSegments) ->startEnd)
    end1Pt2 = cadr(cadr(lineSegments) ->startEnd)
    end2Pt1 = cadr(car(lineSegments) ->startEnd)
    end2Pt2 = car(cadr(lineSegments) ->startEnd)
    end1Pt1 = axlMUniVector(end2Pt1, end1Pt1, axlDistance(end1Pt1, end2Pt1) - 0.1)
    end1Pt2 = axlMUniVector(end2Pt2, end1Pt2, axlDistance(end1Pt2, end2Pt2) - 0.1)
    end2Pt1 = axlMUniVector(end1Pt1, end2Pt1, axlDistance(end1Pt1, end2Pt1) - 0.1)
    end2Pt2 = axlMUniVector(end1Pt2, end2Pt2, axlDistance(end1Pt2, end2Pt2) - 0.1)
    pt1a1 = axlMUniVector(end1Pt2, end1Pt1, axlDistance(end1Pt1, end1Pt2) + 0.15)
    pt1b1 = axlMUniVector(end1Pt2, end1Pt1, axlDistance(end1Pt1, end1Pt2) + 0.41)
    pt2a1 = axlMUniVector(end1Pt1, end1Pt2, axlDistance(end1Pt1, end1Pt2) + 0.15)
    pt2b1 = axlMUniVector(end1Pt1, end1Pt2, axlDistance(end1Pt1, end1Pt2) + 0.41)
    pt1a2 = axlMUniVector(end2Pt2, end2Pt1, axlDistance(end2Pt1, end2Pt2) + 0.15)
    pt1b2 = axlMUniVector(end2Pt2, end2Pt1, axlDistance(end2Pt1, end2Pt2) + 0.41)
    pt2a2 = axlMUniVector(end2Pt1, end2Pt2, axlDistance(end2Pt1, end2Pt2) + 0.15)
    pt2b2 = axlMUniVector(end2Pt1, end2Pt2, axlDistance(end2Pt1, end2Pt2) + 0.41)
    path = axlPathStart(list(pt1a1, pt1b1, pt1b2, pt1a2, pt1a1))
    rectPoly1 = car(axlPolyFromDB(path))
    path = axlPathStart(list(pt2a1, pt2b1, pt2b2, pt2a2, pt2a1))
    rectPoly2 = car(axlPolyFromDB(path))
    routePoly = car(axlPolyOperation(routePoly, list(rectPoly1, rectPoly2), 'ANDNOT))
    shp = car(axlDBCreateShape(routePoly, t, "ROUTE KEEPOUT/ALL"))
