  3. Expand/Contract -> Shape Boundary Segments
  • Replies 7
  • Subscribers 22
  • Views 5425
SambaKantipudi
SambaKantipudi over 1 year ago
Hello All,
I would like to select Cutout Shape(s) and then create a new shape on "ROUTE KEEPOUT/ALL", with an expansion value of 0.4mm. Now I would like to contract the horizontal line segments/paths of the newly created "ROUTE KEEPOUT/ALL" excluding the arc segments with -0.15mm.
Unfortunately, I cannot attach an image to better illustrate.
I would like to achieve the above result using Skill.
Requesting someone for help.
Thanks in advance
Samba
  • Elecguy
    Elecguy over 1 year ago
    Select the shape and create a new shape ... that's clear and easy to do. But what do you mean by "contract the horizontal line segments"?
  • SambaKantipudi
    SambaKantipudi over 1 year ago in reply to Elecguy
    Thanks for your reply.
    A picture is worth a thousand words. But, I don't know the reason why I cannot upload an Image here!!
    I want to select a Cutout shape (Oblong) and expand 0.4MM to RKO/All layer -> I can do this
    I want to contract the lines/path/polygon or what so ever it is called except the semi circles on both sides of the RKO/ALL shape to -0.15MM -> No idea on how to do this!
    Thanks in advance
  • DavidJHutchins
    DavidJHutchins over 1 year ago
    ;;The first step would be to convert the existing shape into a polygon:
    (ShapeList = (axlGetSelSet))
    foreach(shape ShapeList
    if(((shape->objType) == "shape") then
       (PolyList = axlPolyExpand( axlPolyFromDB( shape ?layer (shape->layer) ?padType "REGULAR") Radius 'ACU_BLUNT))
    ;;then contract the outline & build the new shape
      (Offset = (axlMKSConvert -0.15 "MM")
      (layer = "ROUTE KEEPOUT/ALL")
      foreach( poly PolyList
         (RectList = axlPolyExpand(poly Offset 'ACU_BLUNT))
         foreach( result RectList
            (dbids = (axlDBCreateShape result t layer nil nil))
  • SambaKantipudi
    SambaKantipudi over 1 year ago in reply to DavidJHutchins
    Hello David,
    Thankyou.
    My requirement is not fulfilled. Maybe, I could not explain my requirement as a professional understands!
    This portal doesn't allow me to upload an image.
    Can I have your Email ID, so I could share the image of my requirement??
    Thanks in advance
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to SambaKantipudi
    my email is:
    mtnhomecadservices@gmail.com
