  3. Display pads coordinates
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 3545
piorog
piorog over 1 year ago
Hey community!
I would like to display coordinates (and maybe some more useful information) about the padstacks used in the footprint (.dra file). I have managed to prepare the script that shows that information in the command window, but I would prefer to have it displayed in some more user friendly way (for example below the padstack, with the ability to toggle the visibility using some shortcut). Is there any way to achieve such thing? I would be very grateful for some similar examples, as I have no experience with making custom UI in Cadence.
  • DE202408202727
    DE202408202727 over 1 year ago +3 suggested
    defun( Piorog () let((txtBlk, txtOrientation, txtHeight, layerName, text, yLoc) txtBlk = axlUIPrompt(lsprintf("Enter text block integer (between 1 and %d)", axlDBControl('maxTextBlock))) when(txtBlk &&…
  • SaiPavanl
    0 SaiPavanl over 1 year ago
    For the Coordinate of Pins you can use Symbol Pin Report. Tools>Reports>Symbol Pin Reports.
    Using datatips we can get Pin Location when you hover your mouse over the pin. For Customizing datatips, go to Setup>Datatip Customization, Select Pin as Object Type and check the Origin Value.
  • piorog
    0 piorog over 1 year ago in reply to SaiPavanl
    Hi! Thank you four your answer. I know datatips and pin reports, but was wondering if there is any way to make some custom overlay, which would display me these information in more user friendly way (without having to hover each pin separately or generate reports).
  • DE202408202727
    0 DE202408202727 over 1 year ago
    defun( Piorog ()
    when(txtBlk && readstring(txtBlk) <= axlDBControl('maxTextBlock)
    foreach(side, '("TOP", "BOTTOM")
    txtOrientation = make_axlTextOrientation(?textBlock txtBlk, ?justify "center", ?mirrored side == "BOTTOM")
    txtHeight = axlGetParam(lsprintf("paramTextBlock:%s" txtBlk)) ->height
    sprintf(layerName, "BOARD GEOMETRY/PIN_INFO_%s", side)
    axlLayerCreateNonConductor(layerName)
    axlVisibleLayer(layerName, t)
    axlDeleteByLayer(layerName, 'fixed)
    foreach(symbol, setof(sym, axlDBGetDesign() ->symbols, if(side == "TOP" then !sym ->isMirrored else sym ->isMirrored))
    foreach(pin, symbol ->pins
    sprintf(text, "%L", pin ->xy)
    yLoc = lowerLeftY(pin ->bBox) - txtHeight
    axlDBCreateText(text, list(car(pin ->xy), yLoc), txtOrientation, layerName, symbol); Create the text and attach it to the symbol
    axlVisibleUpdate(t)
    • Vote Up +3 Vote Down
  • piorog
    0 piorog over 1 year ago in reply to DE202408202727
    Thank you very much! I will need to adjust it to work with .dra files, but from what I see on .brd it works exactly how it should!
