  3. Toggle subclasses for the current active class
  • State Verified Answer
  • Replies 7
  • Subscribers 21
  • Views 4221
SambaKantipudi
SambaKantipudi over 1 year ago
Hello All,
For the question below, does anyone already have a working solution (SKILL/WoW)?
Currently,
  • funckey + subclass -+ (toggles the visibility, top to bottom)
  • funckey - subclass -- (toggles the visibility, bottom to top)
However, it does not set the existing subclass visibility to "nil."
I would like to make the entire design visibility "nil" and then toggle the subclasses one by one (top to bottom using funckey + & bottom to top using funckey -) for the current active layer.
If there is no SKILL/WoW solution, guidance would also be appreciated.
BR
Samba
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago in reply to SambaKantipudi +1 verified
    Hi Samba! I have adjusted based on your suggestion. Try this: ;++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ axlCmdRegister("++" 'subclassesdown…
  • SambaKantipudi
    0 SambaKantipudi over 1 year ago in reply to Hoangkhoipcb
    Thank you very much again.
    axlVisibleDesign(nil), is still pending.
    Where should I add axlVisibleDesign(nil), to the above code?
    I expect the SKILL to set the design visibility "nil" and then make the subclass visible. This way, I only see the visibility of active class/ sublcass for general CLASS/SUBCLASS and class/ sublcass(es) for ETCH (DRC, PIN, etc.)
  • SambaKantipudi
    0 SambaKantipudi over 1 year ago in reply to SambaKantipudi
    Problem solved
    No further support needed.
    Thankyou
