  3. Toggle subclasses for the current active class
  • State Verified Answer
  • Replies 7
  • Subscribers 21
  • Views 4220
SambaKantipudi
SambaKantipudi over 1 year ago
Hello All,
For the question below, does anyone already have a working solution (SKILL/WoW)?
Currently,
  • funckey + subclass -+ (toggles the visibility, top to bottom)
  • funckey - subclass -- (toggles the visibility, bottom to top)
However, it does not set the existing subclass visibility to "nil."
I would like to make the entire design visibility "nil" and then toggle the subclasses one by one (top to bottom using funckey + & bottom to top using funckey -) for the current active layer.
If there is no SKILL/WoW solution, guidance would also be appreciated.
BR
Samba
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago in reply to SambaKantipudi +1 verified
    Hi Samba! I have adjusted based on your suggestion. Try this: ;++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ axlCmdRegister("++" 'subclassesdown…
  • JuanCR
    0 JuanCR over 1 year ago
    Hi Samba,
    Try this:
    funckey + "QtSignal ColorVisibilityPane CVPGlobalVisOff clicked; subclass -+;setwindow pcb"
    funckey - "QtSignal ColorVisibilityPane CVPGlobalVisOff clicked; subclass --;setwindow pcb"
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    Hello Samba!
    I really don't understand what you all mean.
    You can refer to this code.
    axlCmdRegister("subclass+" 'subclassesdown)
    axlCmdRegister("subclass-" 'subclassesup)
    current_subclasses_down = nil
    current_subclasses_up = nil
    sub_pointer_up = 0
    sub_pointer_down = 0
    (defun subclassesdown ()
    let((sub vi_subclasses current_subclass tmp_list )
    sub_pointer_up = 0
    sub_list = axlSubclassRoute(?field 'isEtch)
    vi_subclasses = findActiveLayer()
    if(vi_subclasses != nil then
    if(sub_pointer_down == 0 && length(vi_subclasses) != 1 then
    printf("Visible must count as 1")
    else
    current_subclass = car(vi_subclasses)
    tmp_list = reverse(member(current_subclass reverse(sub_list)))
    if( tmp_list != current_subclasses_down then
    current_subclasses_down = tmp_list
    if(sub_pointer_down == 0 then
    InviLayers("/")
    InviLayers(strcat("/" lastelem(current_subclasses_down)))
    curent_sub = nth(sub_pointer_down current_subclasses_down)
    if(curent_sub != nil then
    sub_pointer_down++
    InviLayers(strcat("/" curent_sub))
    axlShell("redraw")
    axlVisibleUpdate(nil)
    (defun subclassesup ()
    if(sub_pointer_up == 0 && length(vi_subclasses) != 1 then
    else
    current_subclass = lastelem(vi_subclasses)
    tmp_list = member(current_subclass sub_list)
    if( tmp_list != current_subclasses_up then
    current_subclasses_up = tmp_list
    sub_pointer_up = 0
    if(sub_pointer_up == 0 then
    curent_sub = nth(sub_pointer_up current_subclasses_up)
    InviLayers("/")
    InviLayers(strcat("/" lastelem(current_subclasses_up)))
    else
    curent_sub = nth(sub_pointer_up reverse(current_subclasses_up))
    sub_pointer_up++
    axlShell("redraw")
    (defun InviLayers (curentSub)
    let((isVis)
    if(curentSub =="/" then
    isVis = nil
    else
    isVis = t
    axlVisibleLayer(strcat("DRC ERROR CLASS" curentSub) isVis)
    axlVisibleLayer(strcat("PIN" curentSub) isVis)
    axlVisibleLayer(strcat("VIA CLASS" curentSub) isVis)
    axlVisibleLayer(strcat("ETCH" curentSub) isVis)
    axlVisibleLayer(strcat("PLAN" curentSub) isVis)
    (defun findActiveLayer ()
    let((sub)
    prog((re_layer)
    foreach(subclass axlSubclassRoute(?field 'isEtch)
    if( axlIsVisibleLayer(strcat("ETCH/" subclass)) == t then
    re_layer = cons(subclass re_layer)
    return(re_layer)
    Reguards,
    HoangKhoi.
  • SambaKantipudi
    0 SambaKantipudi over 1 year ago in reply to JuanCR
    Thankyou very much JuanCR
    This works well.
  • SambaKantipudi
    0 SambaKantipudi over 1 year ago in reply to Hoangkhoipcb
    Hello Hoangkhoipcb
    Thankyou very much for you time!
    My requirement:
    For any active class in the design (not only etch), I would like to make the design visibility to nil, and then using funckeys "+" "-", I would like to toggle its subclass layers.
    Example:
    Active class is: Board Geometry
    I would now like to toggle subclasses of B.G, one by one using funckeys "+" "-"
    When the active layer is ETCH, then like in your above code, toggle DRC, PIN, VIA CLASS, ETCH, PLAN etc layers.
    BR
    Samba
  • Hoangkhoipcb
    +1 Hoangkhoipcb over 1 year ago in reply to SambaKantipudi
    Hi Samba!
    Try this:
    axlCmdRegister("++" 'subclassesdown)
    axlCmdRegister("--" 'subclassesup)
    let(( tmp_list )
    tmp_list = DE_subclasses("down")
    if(tmp_list != nil then
    class = car(tmp_list)
    next_sub = cadr(cadr(tmp_list))
    DE_Visiable(class, next_sub)
    let(( tmp_list )
    tmp_list = DE_subclasses("up")
    next_sub = cadr(reverse(cadr(tmp_list)))
    (defun DE_subclasses (tag)
    prog((re_sub)
    layer = axlGetActiveLayer()
    class = car(parseString(layer "/"))
    sub = cadr(parseString(layer "/"))
    sub_list = axlSubclasses(class)
    f_list = sub_list
    if(class !="ETCH" then
    f_list = sort(sub_list 'axlStrcmpAlpNum)
    if(tag =="down" then
    next_subs = member(sub f_list)
    else
    next_subs = reverse(member(sub reverse(f_list)))
    if(length(next_subs) > 1 then
    ;axlVisibleLayer(class nil)
    re_sub = list(class, next_subs)
    return(re_sub)
    (defun DE_Visiable (class, next_sub)
    axlSetActiveLayer(strcat(class "/" next_sub))
    if(class =="ETCH" then
    ;InviLayers("/")
    InviLayers(strcat("/" next_sub))
    else
    axlVisibleLayer(strcat(class "/" next_sub) t)
    axlShell("redraw")
    axlVisibleUpdate(t)
    let((isVis)
    isVis = nil
    else
    isVis = t
    HoangKhoi.
