  3. Test your SKILL Knowledge: Differences between similar ...
  • Subscribers 20
  • Views 6693
Test your SKILL Knowledge: Differences between similar operators
PCBTech
PCBTech over 1 year ago
Assess the SKILL code below.
Do you think it will print the name, type and coordinates of the DRC in the Allegro Command window?
brd=axlDBGetDesign()
allDrcs=brd->drcs
curDRCname=car(allDrcs->name)
curDRCtype=car(allDrcs->type)
curDRCxy=car(allDrcs->xy)
printf("Drc %s of type %s is located at this coordinate%L " curDRCname curDRCtype curDRCxy)
Suggest any alternative approaches.
  • DE202408202727
    DE202408202727 over 1 year ago
    Try this:
    allDrcs=brd->drcs
    curDRCname=car(allDrcs) ->name
    curDRCtype=car(allDrcs) ->type
    curDRCxy=car(allDrcs) ->xy
    printf("Drc '%s' of type '%s' is located at this coordinate: %L\n" curDRCname curDRCtype curDRCxy)
  • DE202408202727
    DE202408202727 over 1 year ago in reply to DE202408202727
    Or this:
    allDrcs=brd->drcs
    curDRCname=car(allDrcs ~>name)
    curDRCtype=car(allDrcs ~>type)
    curDRCxy=car(allDrcs ~>xy)
  • HJerry
    HJerry over 1 year ago
    maybe this:
    ;Find the name, type and xy of the first DRC in the design
    curDRC = car(axlDBGetDesign()->drcs)
    printf( "Drc %s type %s is located at this coordinate:%L\n" curDRC->name curDRC->type curDRC->xy)
  • PCBTech
    Perfect!!Thanks eDave HJerry for replying. They are indeed very helpful and bring a very important aspect for all the SKILL programmers out there:
    Difference between ~> and -> operators while extracting objects and attributes:
    One of the main differences between these operators is that the ~> operator can handle a list on the left-hand side. For a single object these operators are more-or-less interchangeable, but if there is a list of database objects as input to the ~> operator (such as the result of another ~> query of an attribute that yields more than one value), then the ~> operator will apply the attribute query to each member of the list in turn and the result will be the list of each of these queries in turn.
    Notice, curDRCname=car(allDrcs->name) this will give you nil as "allDrcs" is a list and "->" is not able to extract from it. On the other hand, this expression will yield correct results curDRCname=car(allDrcs ~>name)
