  3. Problem with nctape and correct design name
  • State Verified Answer
  • Subscribers 20
  • Views 1848
staticlounge
staticlounge over 1 year ago
Hi Guys
I switched from OrCAD 16.6 to OrCAD X and I'm stuck with a problem with generating drill files via SKILL.
With v16.6 I used the following command:
axlRunBatchDBProgram("Gen Drill Files" "nctape myBoard.brd")
and I got a drill.drl file which contained the correct ;DESIGN name myBoard.brd:
;FILE  : drill-1-4.drl for  ... layers TOP and BOTTOM
;DESIGN: myBoard.brd
;T01 Holesize 1. = 9.100000 Tolerance = +0.000000/-0.000000 PLATED MM Quantity = 9
Now I have to use the following command (with %s) to not get an error message:
axlRunBatchDBProgram("Gen Drill Files" "nctape %s")
but then I end up with the temporary board file name #Taaaaal03632.tmp in the drill file:
;DESIGN: C:/Projects/testboard/#Taaaaal03632.tmp
How can I get the correct file name in the drill file?
Cheers,
Martin
  • mahimag
    mahimag over 1 year ago +1 verified
    Hello staticlounge , you can try below command, this should help. axlRunBatchDBProgram("nctape" strcat("nctape -n " axlCurrentDesign() " %s"))
  • staticlounge
    staticlounge over 1 year ago in reply to mahimag +1
    That works! Awesome, thank you mahimag !
  • mahimag
    +1 mahimag over 1 year ago
  • staticlounge
    0 staticlounge over 1 year ago in reply to mahimag
