  3. Skill to connect selected signal vias by cline
  • Subscribers 20
  • Views 1799
zpofrp
zpofrp over 1 year ago
I have many vias need to connect by cline, now i can only connect one by one manually. i want to use skill to do it.
So I try to do it, but there are many errors in the code.
Can you help me!
here is my thinks.
1. selcet all vias by windws,
2. filters out signal vias, Except PG vias based on CM in properties>Net>Genaral Properties,
3. the line width, line lock and Bubble based on current setup,
4.connect all vias in the same netname.
  • zpofrp
    0 zpofrp over 1 year ago
    I don't upload the pic.
  • andakConsultingLtd
    0 andakConsultingLtd over 1 year ago
    Your request is not clear, that's why you didn't get a reply so far. It si very important to define how these vias are arranged and how you want them connected. This will generate the overall algorithm for parsing them.
    Anyway, breaking things down to the basics, you need to
    1. select the vias and parse the list
    2. based on the way you want to connect them, you need a pair of vias to compute at a time.
    3. extract the (x, y) of each via (start -> end) and add a trace between these points, making sure you also specify the net name. take a look at below code fragment:
       path = axlPathStart(list(0:0 100:100) 5)
       axlDBCreatePath(path "ETCH/TOP" GND)
