  3. Test your SKILL Knowledge: Understanding Variable Scope
  • Subscribers 21
  • Views 2339
PCBTech
PCBTech over 1 year ago
Examine this code sample and predict what will be printed to the console:
globalVar = "Global Variable"
procedure(testScope()
  localVar = "Local Variable"
  printf("In testScope Global: %s Local: %s \n" globalVar localVar )
  let((globalVar)
    globalVar = "Modified"
    localVar = strcat(localVar " with Changes")
    printf("Inner Global: %s Local: %s \n" globalVar localVar )
  printf("After let Global: %s Local: %s \n" globalVar localVar )
printf("Outside testScope Global: %s \n" globalVar )
testScope()
printf("After testscope Global: %s Local: %s \n" globalVar localVar )
How should we change the code to correct variable visibility both inside and outside of the procedure scope?
  • Elecguy
    Elecguy over 1 year ago +1
    Can you clarify what the expected result should be? What exactly do you want to correct? what's the visibility issue? Is it the fact that localVar is modified? or is it related to globalVar? A bit of clarification…
  • Elecguy
    Can you clarify what the expected result should be? What exactly do you want to correct? what's the visibility issue? Is it the fact that localVar is modified? or is it related to globalVar? A bit of clarification would be appreciated ;)
  • PCBTech
    PCBTech over 1 year ago in reply to Elecguy
    The coder's intended local variable is named "localVar" and the intended global variable is named "globalVar". But something is wrong. Can you spot what it is and correct the code so that the variables respect their intended scope? In doing so, you will demonstrate a good understanding of the correct scope assignment of variables in the SKILL language...
  • PCBTech
    As a direct clue to solve this, we hint to users & coders to think of the words of John Lennon: "Let it be".
    With this in mind, can you fix the local variable scope?
