  3. Skill of Import -> Logis/Netlist
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 2701
Maxime1998
Maxime1998 over 1 year ago
Can anyone help me with scripting the skill of the Import -> Logic/Netlist process? I would like to recreate this fonction but I can't figure what it is doing.
Thanks in advance!
  • andakConsultingLtd
    0 andakConsultingLtd over 1 year ago
    Have you tried recording a script via  File->Script? It will create a *.scr file with the following content:
    # Allegro script
    #    file: C:/Users/andakConsultingWork/OneDrive/Work/allegroWork/_Andak/0029_USB_Injector/testScript.scr
    #    start time: Wed Apr 16 19:32:06 2025
    #    Version: 23.1-2023 S008 (4262797) Windows SPB 64-bit Edition
    version 23.1
    setwindow pcb
    netin
    setwindow form.niparams
    FORM niparams directory ./allegro
    FORM niparams import
    setwindow pcb
    #    stop time: Wed Apr 16 19:32:24 2025
  • Maxime1998
    0 Maxime1998 over 1 year ago in reply to andakConsultingLtd
    Thank you very much, it help me a lot. But now I've got another problem. I'm trying to use the command of netin and netrev. But I can figure it the syntax.
    I'm using the fonction axlRunBatchDBProgram to execute the netin and netrev command.
    For now I've written the command like that:
    rep = axlFormGetField(form "repertory")
    pathpcb = strcat( rep "/PCB")
    namenet = strcat(rep "/PCB/netrev.lst")
    pathsch = strcat( rep "/SCHEMA")
    namelog = strcat(rep "/SCHEMA/netlist.log")
    cmd_netin = strcat("netin -$ -g -y 1 -z " namenet " " pathpcb " %s")
    cmd_netrev = strcat("\"C:/Cadence/SPB_17.4/tools/bin/netrev.exe\" -$ -i " pathsch " -z %s")
    axlRunBatchDBProgram("netin" cmd_netin ?logfile namelog ?startMsg "Logic Import")
    axlRunBatchDBProgram("netrev" cmd_netrev ?logfile namelog ?startMsg "Logic Import")
    My problem is that I'm not sure that it is correctly doing th command because my netrev.lst file isn't changed after all.
    Can someone help me?
    0 andakConsultingLtd over 1 year ago in reply to Maxime1998
    Is it a must to use axlRunBatchDBProgram as there are other (easier) commands to run an external program?
    I give up, I think I spent more than 1h on this and I always ended up to square 1. Netin is OK but nothing happens. I am running in cicles, with netin, netrev and missing %s from the command line.
    Worth noted that if you look at netrev lst afer a GUI netin, there is a line that is very close to what you're looking for.
    CmdLine: netrev -i ./allegro -t -y 3 -z -v C:/Users/aghor/OneDrive/Work/allegroWork/skillDevSandBox/#Taaaalv42056.tmp
    Maybe if you tell us what is the ultimate goal, a better idea comes up.
