  3. Python based scripting on Cadence SPB
  • State Suggested Answer
  • Replies 14
  • Answers 1
  • Subscribers 22
  • Views 10818
particlereddy
particlereddy over 1 year ago
newbie question,
This question might have been asked many times.
[1] I could not find any python script based possibility for DRC check automation scripting using python. Did my homework before asking.
[2] all I see is SKILL based scripting.
[q1] Please point me to any UserGuide or programming manual in python [if any]?
[q2] Is it possible via C++?
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago in reply to particlereddy +1 suggested
    Hi! I apologize for the late response Examples using a report from Allegro to export DRC to a file (.csv). Don't launcher Allegro. 100% python script. code Python import subprocess input_data…
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    Hi particlereddy!
    Sure. It works me well.
    HoangKhoi.
  • Hoangkhoipcb
    Sure. It work me well.
    I can't upload images on site at the moment.
    HoangKhoi.
  • andakConsultingLtd
    0 andakConsultingLtd over 1 year ago
    Indeed it as discussed before. Are you interested in talking to OrCAD Capture or OrCAD PCB?
    Capture has a communication server available on port 9020 where you can post messages. This is discussed in the documentation.
    For PCB, there is no server available, but it is much easier to implement I think (I didn;t do it personally). Definetly some endpoint need to be created in SKILL which would require some port handling (curl.exe could do it or any other c/c++ app).
  • KD202502275710
    0 KD202502275710 over 1 year ago in reply to andakConsultingLtd
    Works for me
  • particlereddy
    0 particlereddy over 1 year ago in reply to Hoangkhoipcb
    can you point me to any manual, user guide in this regard?
