  3. Scope of Global and Local variables in Allegro SKILL
  • Subscribers 20
  • Views 4330
JuanCR
JuanCR over 1 year ago
By default, all variables in Allegro SKILL are global. Their value is accessible at any time and anywhere within your SKILL Code.
The use of global variables in SKILL, as with any language, should be kept to a minimum.
Global variables in SKILL
For example, in the code snippet given below, x1 and x2 become global variables by default. You can also access them from within a procedure.
x1 = 5
x2 = 10
procedure( update_vars(number1 number2)
printf("Inside proc:\t x1 is %d\t x2 is %d\t sum is %d\n" x1 x2 x1+x2)
x1 = number1
x2 = number2
printf("Before sum:\t x1 is %d\t x2 is %d \n" x1 x2)
update_vars(50 100)
printf("After sum: \t x1 is %d\t x2 is %d \n" x1 x2)
The result is:
Defining local variables
You can define local variables by using let or prog.
x1 = 5
x2 = 10
procedure( Local_Sum(number1 number2)
   let( (x1 x2); notice we're intentionally using the same variable names
      x1 = number1
      x2 = number2
      printf("Inside Local_Sum:\t x1 is %d\t x2 is %d\t sum is is %d\n" x1 x2 x1+x2)
printf("Before Local_Sum:\t x1 is %d\t x2 is %d\t sum is is %d\n" x1 x2 x1+x2)
Local_Sum(1 2)
printf("After Local_Sum:\t x1 is %d\t x2 is %d\t sum is is %d\n" x1 x2 x1+x2)
The result is:
Interesting, isn't it? Play with the code snippets and let us know if you have any questions!
