  3. Object Properties
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 3888
Object Properties
JuriVi
JuriVi over 1 year ago
Hello everybody,
I want to print the attributes of the text using a loop. Example:
p = axlGetParam(strcat("paramTextBlock:" str))
text_attr_list =   '(charSpace height lineSpace name objType photoWidth userDefined width )
for(u 1 7
                    attr = nth(u text_attr_list)
                    printf("%A\n " p->attr)
    ); end for
But it does't work. My suggestion is p->attr is not correct.
Everybody knows how to fix it?
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago +1
    Hello! Why are my replies often marked as spam in this forum? wait admin approval for the post. so bored. foreach(textblock axlGetParam("paramTextGroup")->groupMembers println(axlGetParam(strcat…
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    Hello!
    foreach(textblock axlGetParam("paramTextGroup")->groupMembers println(axlGetParam(strcat("paramTextBlock:" textblock))->?? ) )
  • JuriVi
    0 JuriVi over 1 year ago in reply to Hoangkhoipcb
    Hi Hoangkhoi,
    thank you for reply. I will test it.
  • JuriVi
    0 JuriVi over 1 year ago in reply to JuriVi
    Thank you, it is helpfull!
    Nevertheless, do you know why my code doesn't work:
    text_attr_list =   '(charSpace height lineSpace name objType photoWidth userDefined width ) ; list of text attributes
                        attr = nth(u text_attr_list)  ; for u = 2 getting attr = height
                        printf("%A\n " p->attr)       ; p is e.g param:000001FF990E70A0,
        ; obtaining from p = axlGetParam(strcat("paramTextBlock:" str))
    But p->attr, means p->height brings nil. For p->height I got the real size of the text.
    What is wrong? Should be "attr" a string?
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago in reply to JuriVi
    I really don't know why it is wrong. But you can also refer to this code.
    (defun text_attr ()
    p = axlGetParam(strcat("paramTextBlock:1"))
    println(p)
    for(u 1 7
    printf("%L\n " evalstring(strcat("p->" attr)))
    ); end for
    HoangKhoi.
  • JuriVi
    Hi HoangKhoi,
    thank you! It works. The mistake was, the p should be a string:
    p->attr results nil
    "p" -> attr results width
