  3. Exporting Layout Views as SVG Using SKILL in Allegro
  • State Suggested Answer
  • Answers 1
  • Subscribers 22
  • Views 3564
SambaKantipudi
SambaKantipudi over 1 year ago
Hello Community,
Is there a way to convert layout views to SVG format using SKILL?
For example, I'd like to export film views such as Assembly, Soldermask, etc.
I’m looking for methods or best practices to generate high-quality SVG output directly from Allegro using SKILL scripts.
Thanks in advance
BR
Samba
  • DE202408202727
    DE202408202727 over 1 year ago in reply to andakConsultingLtd +2 suggested
    Certainly you can use Skill to convert to your layout features to SVG and I have done exactly that. It's not difficult but it does involve a large amount of code writing and a reasonable understanding…
  • andakConsultingLtd
    andakConsultingLtd over 1 year ago in reply to KD202502275710 +1
    You can use an online tool or Inkscape to export an SVG from a PDF. Alternatively, a skill can do the job, but there is a significant amount of work since every single database element needs to be transferred…
    0 andakConsultingLtd over 1 year ago
    you can export them to pdf for now.
  • KD202502275710
    0 KD202502275710 over 1 year ago in reply to andakConsultingLtd
    But is there any other alternative?
    0 andakConsultingLtd over 1 year ago in reply to KD202502275710
    Alternatively, a skill can do the job, but there is a significant amount of work since every single database element needs to be transferred to SVG.
  • DE202408202727
    0 DE202408202727 over 1 year ago in reply to andakConsultingLtd
    It's not difficult but it does involve a large amount of code writing and a reasonable understanding of SVG syntax.
    My advice is to start writing functions to convert each element into SVG - lines, arcs, polygons, pads etc.
    Allow for location, scale, colour, transparency etc in each function.
    Good luck!
    • Vote Up +2 Vote Down
