  3. Deleting Degassing Voids Using Skill - axlShapeEraseDeg...
  • State Verified Answer
  • Replies 8
  • Subscribers 21
  • Views 7111
Deleting Degassing Voids Using Skill - axlShapeEraseDegassingHole
AnanthVedalaLM
AnanthVedalaLM over 1 year ago
I'm trying to delete degas voids that are auto generated by Shape Degassing tool in APD using Skill script, for which i'm using this function axlShapeEraseDegassingHole , the arguments required are shape dbid and location of the holes,
parentShape = void->parent
eraseResult = axlShapeEraseDegassingHole(parentShape ?location location)
but the result is always nil. can anyone give an example script to do this operation.
  • mahimag
    mahimag over 1 year ago in reply to AnanthVedalaLM +2 verified
    Hi, Correct API Usage: The axlShapeEraseDegassingHole function is designed for advanced degassing holes, not regular ones. For regular degassing holes, the axlShapeDeleteVoids API should be used. Recommended…
  • mahimag
    mahimag over 1 year ago +1
    Hi AnanthVedalaLM , this SKILL API is for the Adv Degassing holes. If you are working on the regular degassing holes, try selecting them using SKILL selection commands. turn on only boundary from color…
  • zpofrp
    0 zpofrp over 1 year ago in reply to mahimag
    run this code
    void_list = shape->voids
    SYNTAX ERROR found at line 9 column 19 of file del_degas.il
    *Error* lineread/read: syntax error encountered in input
    *Error* eval: unbound variable - shape
  • mahimag
    0 mahimag over 1 year ago in reply to zpofrp
    Thanks for pointing out zpofrp , there was a typo in my code, it should be void_list=shape->voids
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago in reply to mahimag
    Hi mahimag!
    My static shape has 3 million degassings, and my client requires me to remove the degassings. I used the function axlShapeDeleteVoid(degass), but it didn’t work for me.
    Best & Regards,
    HoangKhoi
