  3. I Need Help Creating a Shape With a Void on Route Keepout...
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 4045
I Need Help Creating a Shape With a Void on Route Keepout in Allegro
MarkGorecki
MarkGorecki over 1 year ago
I followed the instructions in the Allegro X PCB Editor Skill Programming Language course, but it seems to be missing something.
Shown below is my code to create a rectangular shape, with rounded corners, then add a void, also with rounded corners, to that shape.
procedure(CreateHSKO_Callback(formStatus)
let( (lidX lidY cavityX cavityY lidType lidRadius lidCham cavRadius
lidX1 lidX2 lidX3 lidX4 lidY1 lidY2 lidY3 lidY4 chamX chamY cavX1 cavX2 cavX3 cavX4
cavY1 cavY2 cavY3 cavY4 hsPath voidPath)
lidX = 0
lidY = 0
cavityX = 0
cavityY = 0
lidType = nil
lidRadius = 0
lidCham = 0
cavRadius = 0
lidX1 = 0
lidX2 = 0
lidX3 = 0
lidX4 = 0
lidY1 = 0
lidY2 = 0
lidY3 = 0
lidY4 = 0
chamX = 0
chamY = 0
cavX1 = 0
cavX2 = 0
cavX3 = 0
cavX4 = 0
cavY1 = 0
cavY2 = 0
cavY3 = 0
cavY4 = 0
hsPath = 0
voidPath = 0
case(formStatus~>curField
("dwgNum" dwgNumber = formStatus~>curValue)
("done"
hsPort = infile("C:/_Temp/SKILL/Test_HeatSpreader_Data.csv")
numFound = "F"
when(hsPort
while(gets(txtLine hsPort)
infoList = parseString(txtLine ",")
listDwgNum = nth(0 infoList)
printf( "Drawing Number: %s\n" listDwgNum )
if(listDwgNum == dwgNumber then
numFound = "T"
;Flat Top Lid - 1500chamfer/500rad corner : 1000 rad cavity
;Single Piece Lid - 500rad corners : 1000 rad cavity
;2 Piece Stiffener/Stiffener Only - 1500chamfer : 1000 rad cavity
lidX = atof(nth(1 infoList))
lidY = atof(nth(2 infoList))
cavityX = atof(nth(3 infoList))
cavityY = atof(nth(4 infoList))
lidType = nth(5 infoList)
lidRadius = 500.0
lidCham = 1500.0
cavRadius = 1000.0
lidX1 = (lidX / 2.0) * -1
lidX2 = (((lidX / 2.0) - lidRadius) * -1)
lidX3 = (lidX / 2.0) - lidRadius
lidX4 = lidX / 2.0
lidY1 = (lidY / 2.0) * -1
lidY2 = (((lidY / 2.0) - lidRadius) * -1)
lidY3 = (lidY / 2.0) - lidRadius
lidY4 = lidY / 2.0
chamX = lidX1 + lidCham
chamY = lidY4 - lidCham
cavX1 = (cavityX / 2.0) * -1
cavX2 = (((cavityX / 2.0) - cavRadius) * -1)
cavX3 = (cavityX / 2.0) - cavRadius
cavX4 = cavityX / 2.0
cavY1 = (cavityY / 2.0) * -1
cavY2 = (((cavityY / 2.0) - cavRadius) * -1)
cavY3 = (cavityY / 2.0) - cavRadius
cavY4 = cavityY / 2.0
; Create the lid outline
if(lidType == "FTL" then
hsPath = axlPathStart((list lidX2:lidY1) 0)
hsPath = axlPathLine(hsPath 0.0 lidX3:lidY1)
hsPath = axlPathArcCenter(hsPath 0.0 lidX4:lidY2 nil lidX3:lidY2)
hsPath = axlPathLine(hsPath 0.0 lidX4:lidY3)
hsPath = axlPathArcCenter(hsPath 0.0 lidX3:lidY4 nil lidX3:lidY3)
hsPath = axlPathLine(hsPath 0.0 chamX:lidY4)
hsPath = axlPathLine(hsPath 0.0 lidX1:chamY)
hsPath = axlPathLine(hsPath 0.0 lidX1:lidY2)
hsPath = axlPathArcCenter(hsPath 0.0 lidX2:lidY1 nil lidX2:lidY2)
if(lidType == "SPL" then
hsPath = axlPathLine(hsPath 0.0 lidX2:lidY4)
hsPath = axlPathArcCenter(hsPath 0.0 lidX1:lidY3 nil lidX2:lidY3)
if(lidType == "2PS" || lidType == "SO" then
hsPath = axlPathStart((list lidX1:lidY1) 0)
hsPath = axlPathLine(hsPath 0.0 lidX4:lidY1)
hsPath = axlPathLine(hsPath 0.0 lidX4:lidY4)
hsPath = axlPathLine(hsPath 0.0 lidX1:lidY1)
hsShape = axlDBCreateOpenShape(hsPath t "ROUTE KEEPOUT/L01" nil)
voidPath = axlPathStart((list cavX2:cavY1) 0)
voidPath = axlPathLine(voidPath 0.0 cavX3:cavY1)
voidPath = axlPathArcCenter(voidPath 0.0 cavX4:cavY2 nil cavX3:cavY2)
voidPath = axlPathLine(voidPath 0.0 cavX4:cavY3)
voidPath = axlPathArcCenter(voidPath 0.0 cavX3:cavY4 nil cavX3:cavY3)
voidPath = axlPathLine(voidPath 0.0 cavX2:cavY4)
voidPath = axlPathArcCenter(voidPath 0.0 cavX2:cavY1 nil cavX2:cavY2)
axlDBCreateVoid(hsShape voidPath)
axlDBCreateCloseShape(hsShape)
) ;if dwgNumber
) ;while
if(numFound == "F" then axlUIConfirm( "Drawing number not found!" ))
close(hsPort)
axlFormClose(myform)
("cancel"
) ;case
) ;let
I get this error:
W- *WARNING* (axlDBCreatePath): Not an r_path defstruct - 0
W- *WARNING* (axlDBCreateOpenShape): Object should be either an r_path or an o_polygon - 0
I created the paths like they showed, as the course said "The first argument is a path handle created with the axlPath () functions previously discussed."
If someone would help me out, I would really appreciate it.
Best regards,
Mark
  • DE202408202727
    0 DE202408202727 over 1 year ago
    Hi Mark,
    Most of your code won't execute correctly because you have used "~" in place of "-" in formStatus~>curField and formStatus~>curValue
    BTW, you don't need to (read "shouldn't") zero all your variables. They are declared correctly as nil in your let statement.
    Dave
  • MarkGorecki
    0 MarkGorecki over 1 year ago in reply to DE202408202727
    Hi Dave,
    Thank you for checking out my code and for the advice.  I also found an error in my void path.  It's working now.
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to MarkGorecki
    I would recommend using sklint() to check your code, below is the results I got:
    C:\Temp>il_allegro
    > sklint(?file "test.ils")
    Loading skillLint.cxt
    INFO (LoadFile): Loading file C:\Cadence\SPB_22.1\tools\sklint/rules/allegro_sklint.il...
    INFO (LoadFile): Loading file C:\Cadence\SPB_22.1\tools\sklint/rules/hi2ipc.il...
    INFO (LoadFile): Loading file C:\Cadence\SPB_22.1\tools\sklint/rules/ignore.il...
    INFO (LoadFile): Loading file C:\Cadence\SPB_22.1\tools\sklint/rules/ilMig.il...
    INFO (REP008): Program SKILL Lint started on Aug 14 09:53:47 2025.
    INFO (PREFIXES): Using prefixes: "none"
    INFO (STRICT): Using strict checking of global variables.
    HINT (NTH1): test.ils, line 14 (CreateHSKO_Callback) : Can replace call to nth with call to car: nth(0 infoList)
    HINT (NTH1): test.ils, line 21 (CreateHSKO_Callback) : Can replace call to nth with call to cadr: nth(1 infoList)
    HINT (NTH1): test.ils, line 22 (CreateHSKO_Callback) : Can replace call to nth with call to caddr: nth(2 infoList)
    UNUSED VAR (Unused): test.ils, line 2 (CreateHSKO_Callback) : variable cavX1 does not appear to be referenced. (assigned only)
    INFO (VAR5): Unrecognized global variables:
    WARN GLOB (VAR8): dwgNumber
    INFO (VAR): used in Scheme:  in function CreateHSKO_Callback from file test.ils, line 16
    INFO (VAR): set in Scheme:   in function CreateHSKO_Callback from file test.ils, line 7
    WARN GLOB (VAR8): hsPort
    INFO (VAR): used in Scheme:  in function CreateHSKO_Callback from file test.ils, lines (93 12 11)
    INFO (VAR): set in Scheme:   in function CreateHSKO_Callback from file test.ils, line 9
    WARN GLOB (VAR8): hsShape
    INFO (VAR): used in Scheme:  in function CreateHSKO_Callback from file test.ils, lines (88 87)
    INFO (VAR): set in Scheme:   in function CreateHSKO_Callback from file test.ils, line 79
    WARN GLOB (VAR8): infoList
    INFO (VAR): used in Scheme:  in function CreateHSKO_Callback from file test.ils, lines (25 24 23 22 21 14)
    INFO (VAR): set in Scheme:   in function CreateHSKO_Callback from file test.ils, line 13
    WARN GLOB (VAR8): listDwgNum
    INFO (VAR): used in Scheme:  in function CreateHSKO_Callback from file test.ils, lines (16 15)
    INFO (VAR): set in Scheme:   in function CreateHSKO_Callback from file test.ils, line 14
    WARN GLOB (VAR8): myform
    INFO (VAR): used in Scheme:  in function CreateHSKO_Callback from file test.ils, lines (97 94)
    WARN GLOB (VAR8): numFound
    INFO (VAR): used in Scheme:  in function CreateHSKO_Callback from file test.ils, line 91
    INFO (VAR): set in Scheme:   in function CreateHSKO_Callback from file test.ils, lines (17 10)
    WARN GLOB (VAR8): txtLine
    INFO (VAR): used in Scheme:  in function CreateHSKO_Callback from file test.ils, lines (13 12)
    INFO (IQ): IQ score is 0 (best is 100).
    INFO (IQ1): IQ score is based on 0 error messages, 9 general warning messages, and 1 top level forms.
    INFO (REP110): Total enhancement     : 0.
    INFO (REP110): Total external global : 0.
    INFO (REP110): Total package global  : 0.
    INFO (REP110): Total warning global  : 8.
    INFO (REP110): Total error global    : 0.
    INFO (REP110): Total unused vars     : 1.
    INFO (REP110): Total next release    : 0.
    INFO (REP110): Total alert           : 0.
    INFO (REP110): Total hint            : 3.
    INFO (REP110): Total suggestion      : 0.
    INFO (REP110): Total internal alert  : 0.
    INFO (REP110): Total information     : 31.
    INFO (REP110): Total warning         : 0.
    INFO (REP110): Total error           : 0.
    INFO (REP110): Total internal error  : 0.
    INFO (REP110): Total fatal error     : 0.
    INFO (REP009): Program SKILL Lint finished on Aug 14 09:53:48 2025 with status PASS.
    t
  • MarkGorecki
    0 MarkGorecki over 1 year ago in reply to DavidJHutchins
    Hi David, thank you for that info.  I'll look into sklint.
