  3. Need Help with Code to find Package to Place Keepout DRC...
  • State Verified Answer
  • Subscribers 21
  • Views 3607
Need Help with Code to find Package to Place Keepout DRC's
MarkGorecki
MarkGorecki over 1 year ago
I'm using Cadence APD 24.1 and have written a Skill program that will create custom keepout areas on "Component Keepout/Top".
Cadence does not consider these to be active DRC's so the bowties do not automatically show up when an SMD component crosses the component keepout shape edge.
I can use:  Tools > DRC Browser > DRC(4) > Design(2) > Package > Package to place keepout  which will list the errors and give the coordinates.  If I pick the coordinate, it will center the DRC in the design and then show a bowtie.
Is there a way to do this action using Skill code?  I could have a pop-up mesage that tells the designer how to do this, but I think it would be better if the code was able to do this.
Any help would be greatly appreciated.
Best regards,
Mark
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to MarkGorecki +2 verified
    Below is an example that should work in both Allegro and APD: (axlVisibleLayer strcat(axlMapClassName("PACKAGE") "KEEPOUT/TOP") t)
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago
    I am running Cadence Allegro 23.1 & do not see any issues with getting DRC's on newly added keepout shapes on "Package Keepout/Top"
    Can you try running your code on an previous release?
  • MarkGorecki
    0 MarkGorecki over 1 year ago in reply to DavidJHutchins
    Since I posted this, I learned that if you turned on the NON-CONDUCTOR/PACKAGE_TOP layer, you would see the bowties.  So now I'm updating the code to check if that layer is currently visible, and if not, to make it visible.
  • DavidJHutchins
    +1 DavidJHutchins over 1 year ago in reply to MarkGorecki
    • Vote Up +2 Vote Down
  • MarkGorecki
    Hi David, thanks for the code.  I ended up using this:
    if(not(axlIsVisibleLayer("DRC ERROR CLASS/PACKAGE_TOP")) then
    ; Set the layer to be visible
    axlVisibleLayer("DRC ERROR CLASS/PACKAGE_TOP" t)
    ; Update the display to show the changes
    axlFlushDisplay()
