  3. Using SKILL to route differential pair
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 2564
In2p3SubRenard
In2p3SubRenard over 1 year ago
Hello, I am trying to use SKILL to route differential pairs.
axlDBCreateLine() routes the lines without taking into account the diff-pair constraints.
Is there a way to route both lines of a diff-pair at the same time using SKILL in the same way as when I use "Add Connect" in the User Interface ?
  • JuanCR
    0 JuanCR over 1 year ago
    This is unfortunately a limitation of the tool. Currently only single ended routing is possible using the command you've shared.
  • In2p3SubRenard
    0 In2p3SubRenard over 1 year ago
    I managed to route differential lines using
    v_axlShellTxt = sprintf(nil "add connect -h ; pick %L ; pick %L" nth(0 v_PinCenterList) nth(1 v_PinCenterList))
    axlShell(v_axlShellTxt)
