  3. Issue with function @key parameters
  • State Suggested Answer
  • Answers 2
  • Subscribers 20
  • Views 1555
DavidJHutchins
DavidJHutchins over 1 year ago
I have noticed an issue with @key parameter default values not getting processed correctly...
Below is an example code segment:
procedure( test_code(
@key ( PseudoName "psuedo_tp")
( PreFix "_TP")
( Debug t)
let((Mark PreFix Comps net count Status)
when(Debug printf("PseudoName %A PreFix %A Debug %A\n" PseudoName PreFix Debug))
;; initialize variables
(count = 0)
unless(stringp(PseudoName) (PseudoName = "PSUEDO_TP"))
unless(stringp(PreFix) (PreFix = "_TP"))
When I run this is Allegro, the Prefix parameter default value of "_TP" is discarded, as shown below:
\i (00:00:47) skill test_code
(00:00:47) PseudoName "psuedo_tp" PreFix nil Debug t
(00:00:47) PseudoName "psuedo_tp" PreFix "_TP" Debug t
(00:00:47) t
Has anyone else seen this issue? if so, what is the solution...
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago
    Never mind, I should have used sklint to identify the issue, as reported below:
    INFO (VAR16): allegro_test_code.ils, line 6 (test_code) : declaration of variable PreFix supersedes previous declaration at line 1.
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    Hi Davi,
    The default value of the Prefix parameter "_TP" is always nil, because it is defined inside the let(PreFix) function.
    Best regards,
    Hoang Khoi
