  3. Running ODB++ without GUI
  • State Suggested Answer
  • Answers 1
  • Subscribers 21
  • Views 4067
Uri Chaplin
Uri Chaplin 11 months ago
I try to create ODB++ files without a GUI.  I used ODB++ Inside  board and checked that no warning to brd file I going to use.
First I created a BAT file to check if all parameters are good.
 I run this file :
SET ALLEGRO_BOARD="c:\ODB\test.brd"
SET OUTPUT_DIR="c:\ODB\odb_export"
SET ALLEGRO_BRD2ODB="c:\ODB\brd2odb_2510\"
%ALLEGRO_BRD2ODB%brd2odb.exe -ijp %ALLEGRO_BOARD%  -jp %OUTPUT_DIR% -jn allegro_1  -no_view -noDPW
pause
But it always open GUI and report error: Translation filed ! Some required files are missing ( elf_cadence-583004)
What is wrong ?
  • Ejlersen
    Ejlersen 11 months ago +1
    Hi Uri It is necessary to notice 2 things when generating odb++ in batch mode 1. you must extract data using provided "valor" script 2. you must specify films, there has to be etch layer films as…
  • Ejlersen
    0 Ejlersen 11 months ago
    Hi Uri
    2. you must specify films, there has to be etch layer films as far as I remember
    I'm doing the following to extract data
    - copy extract skill script locally, load it and then run it.
    axlOSFileCopy(strcat(axlOSSlash(axlGetVariable("ALLEGRO_BRD2ODB")) "/valor_ext.il") strcat(getWorkingDir() "/valor_ext.il") nil)
    load("./valor_ext.il")
    tmp_file = axlDMOpenFile("ALLEGRO_SCRIPT", "./tmp", "w")
    fprintf(tmp_file "scriptmode +i +w +c\n")
    fprintf(tmp_file "setwindow pcb\n")
    fprintf(tmp_file "valor extract info\n")
    fprintf(tmp_file "fillin no\n")
    axlDMClose(tmp_file)
    axlShell("replay ./tmp.scr")
    when(isFile("./tmp.scr") deleteFile("./tmp.scr"))
    Then I build a run string for batch, you must play with the options on your own
    sprintf(cmd, "\"%s\" -jn \"%s\" -jp \"%s\" -ijp \"%s\" -gzip -sf -sp -no_view -padflash ignore -nn -read_sqa no -odb_version v8 -component assembly\n"
    strcat(axlOSSlash(axlGetVariable("ALLEGRO_BRD2ODB")) "/brd2odb.exe")
    outputfilename
    strcat(axlOSSlash(getWorkingDir()))
    strcat(axlOSSlash(getWorkingDir()) "/" axlCurrentDesign() ".brd")
    Finally I run the batch process
    res = axlRunBatchDBProgram("brd2odb" cmd ?noUnload t ?silent t ?noProgress t)
    Hope this helps
    Ole
  • Uri Chaplin
    0 Uri Chaplin 11 months ago in reply to Ejlersen
    Thanks !
    I will try.
  • Uri Chaplin
    It's work !  No one is not informed that first must create Extracted files.
    Thanks !
  • MZ20250602835
    0 MZ20250602835 8 months ago in reply to Ejlersen
    Many thanks for your codes.
    it guides me to create ODB++ files with batch instead of a GUI.
    Best Regards
    Moyan
