  3. How to use Allegro Skill language to check if the height...
  • State Suggested Answer
  • Answers 2
  • Subscribers 22
  • Views 3829
How to use Allegro Skill language to check if the height of bottom components are more than 4mm and highlight them
BZ202408076026
BZ202408076026 9 months ago
I am newcomer for Cadence Skill language and I am learning on how to develop programing to check what I want in Cadence Allegro.
Now I want to check if the height of bottom components are more than 4mm and highlight them if existed. But I don't know where to start. Does anybody have the experience to write the Skill?
  • Hoangkhoipcb
    Hoangkhoipcb 9 months ago +1 suggested
    Hi BZ, You can refer to the code below. axlCmdRegister ( "find_height_symbol" 'find_height_symbol ) ( defun find_height_symbol ( ) ( let () convert_design_unit = axlMKSConvert ( 4 "MM" car (…
  • JCTEYSSIER0
    JCTEYSSIER0 9 months ago in reply to BZ202408076026 +1 suggested
    The keepout is not to be included in library but in the brd using the components. If component have a correct place boundary defined (with height) then the place keepout is to be defined at pcb (brd…
  • SOT23
    0 SOT23 9 months ago in reply to JCTEYSSIER0
    This is the correct answer. You create a Package Keepout/Bottom shape over the area you don't want the component to be taller than 4mm. Then using Setup > Area > Package height, you set the minimum height to 4mm. You will have a DRC marker at every component that does not respect that rule.
