  3. How to use Allegro Skill language to check if the height...
  • State Suggested Answer
  • Answers 2
  • Subscribers 22
  • Views 3828
How to use Allegro Skill language to check if the height of bottom components are more than 4mm and highlight them
BZ202408076026
BZ202408076026 9 months ago
I am newcomer for Cadence Skill language and I am learning on how to develop programing to check what I want in Cadence Allegro.
Now I want to check if the height of bottom components are more than 4mm and highlight them if existed. But I don't know where to start. Does anybody have the experience to write the Skill?
  • Hoangkhoipcb
    Hoangkhoipcb 9 months ago +1 suggested
    Hi BZ, You can refer to the code below. axlCmdRegister ( "find_height_symbol" 'find_height_symbol ) ( defun find_height_symbol ( ) ( let () convert_design_unit = axlMKSConvert ( 4 "MM" car (…
  • JCTEYSSIER0
    JCTEYSSIER0 9 months ago in reply to BZ202408076026 +1 suggested
    The keepout is not to be included in library but in the brd using the components. If component have a correct place boundary defined (with height) then the place keepout is to be defined at pcb (brd…
  • Hoangkhoipcb
    0 Hoangkhoipcb 9 months ago
    Hi BZ,
    axlCmdRegister("find_height_symbol" 'find_height_symbol)
    (defun find_height_symbol ()
        (let ()
            convert_design_unit = axlMKSConvert(4 "MM" car(axlDBGetDesignUnits()))
            foreach(shape axlDBGetShapes("PACKAGE GEOMETRY/PLACE_BOUND_BOTTOM")
                sym = shape->parent
                if(sym != nil then
                    pro = car(setof(e axlDBGetProperties(shape) get_string(car(e)) =="PACKAGE_HEIGHT_MAX"))
                    if(pro != nil then
                        if(atof(cadr(pro)) > convert_design_unit then
                            axlHighlightObject(sym)
    BR
    HoangKhoi.
  • BZ202408076026
    0 BZ202408076026 9 months ago in reply to Hoangkhoipcb
    Thank you Hoanghoi!
    I will verify if the code is workable in Cadence.
  • JCTEYSSIER0
    0 JCTEYSSIER0 9 months ago
    Why not just add a package keepout bottom side starting at 4mm heiht?
    You will get drc if bottom component is heigher
  • BZ202408076026
    0 BZ202408076026 9 months ago in reply to JCTEYSSIER0
    Good question. But we have a lot of components in our library. If we will add package keepout, it is very huge workload for us. also, lib team is not part of us. So we prefer to develop skill script to cover this check.
  • JCTEYSSIER0
    0 JCTEYSSIER0 9 months ago in reply to BZ202408076026
    If component have a correct place boundary defined (with height) then the place keepout is to be defined at pcb (brd) level.
    Place boundary (so in package) represent solid volume. Two volumes cannot intersect
    Package keepout represents area where these volumes are prohibited.
