  3. menu creation in orcad pcb skill
  • State Verified Answer
  • Subscribers 21
  • Views 1878
digital1
digital1 9 months ago
Hi i have created a routine in skill to run in pcb editor this code runs and does its thing however i now want to code a menu so the menu is inserted at startup.
i have inserted the file to load in my allegro.ilinit as  (load "net_short.il")
the top of my net_short.il file is
q = axlUIMenuFind(nil -1)
z = axlUIMenuInsert( q 'popup "TDR Electronics")
axlUIMenuInsert(z "Net Short" "net_short")
axlCmdRegister("net_short" `_net_short)
however there is no menu at the top of the pcb editor and it should be left of the help menu the code has been loaded because when i type net_short in the command window the code runs
however i can type in the command window skill load "net_short.il" and the menu has my updated menu in it and i can then run the code from that menu.
I believe it is a timing issue but i dont know how to get any further I am running orcad pcb version 24.1
can any one help
  • JuanCR
    JuanCR 9 months ago +1 verified
    Hi digital1 Can you try adding the following to your allegro.ilinit? Then open the tool. load(" net_short.il ") ; SKILL Code Menu SKILLToolsMenu = '( (popup "Custom Menu") ( popup "Net Short…
  • JuanCR
    +1 JuanCR 9 months ago
    Hi digital1
    load("net_short.il")
    ; SKILL Code Menu
    SKILLToolsMenu = '(
          ( popup "Net Short" )
             ( "Net Short" "net_short" (regular layout symbol ) )
          (end)
       (end)
    procedure( MenuTrig(t_menufile)
       let( (q)
       res = axlUIMenuInsert(q SKILLToolsMenu)
    axlTriggerSet('menu  'MenuTrig)
    Alternatively, for a simplified look, you could replace SKILLToolsMenu by:
    SKILLToolsMenu = '(
          ("Net Short" "net_short" (regular layout symbol ) )
       (end)
    Let me know if this works.
  • digital1
    0 digital1 9 months ago in reply to JuanCR
    Hi JuanCR Sorry it took me a while to come back but that worked perfectly thank you very much.
