  3. customized GUI to control artwork film
  • State Verified Answer
  • Subscribers 20
  • Views 1316
MZ20250602835
MZ20250602835 5 months ago
Dear all,
i would like to use film_domain.form as the base to create a customized GUI in which the user/Layouter can assign specific artwork films for Artwork and PDF domains(the Domains IPC2581 and Visibility will not be displayed).
may i ask in my case which skill should i used to achieve the expected function?
Many thanks
Moyan
  • techiecs
    techiecs 5 months ago +1 verified
    From my understanding, you're looking to create artwork film creation through SKILL API and then modify the parameters and other artwork controls through SKILL only, here are a few SKILL APIs which you…
  • techiecs
    +1 techiecs 5 months ago
    From my understanding, you're looking to create artwork film creation through SKILL API and then modify the parameters and other artwork controls through SKILL only, here are a few SKILL APIs which you may use to explore for your requirement and achieve the film related tasks:
    1. axlFilmCreate
    -Creates a new artwork film or replaces an existing artwork film.
    Eg: axlFilmCreate("Testfilm", ?layers '("ETCH/INNER1"))
    2. axlVisibleUpdate() function to update any form that display color or visibility to the user. So, after creating films, you must run the display update to see the changes.
    3. axlGetParam() function gets parameter dbid for a named object.
    Eg: You can check the names of existing films by typing the following SKILL command at the Skill prompt:
    axlGetParam("artwork")->??
    (This will list the current films in the design.)
    4. axlDeleteObject() which deletes single or list of database bjects from database.
    You can delete all artwork films in the design by using the following SKILL command:
    axlDeleteObject(axlGetParam("artwork"))
    This will delete all films (individual and default) from the design.
    5. You can get film's specific parameters using axlGetParam() function by using commands like
    axlGetParam("artwork")->groupMembers
    axlGetParam("artwork:TOP")
    axlGetParam("artwork:TOP")~>??
    axlGetParam("artwork:TOP")~>undefineLineWidth
    Suggested these SKIL APIs which you may look as an example to begin with.
    You may refer the Allegro SKILL User Guide which lists the details about these SKILL API and its related parameters in detail.
    I hope this helps.
  • MZ20250602835
    0 MZ20250602835 5 months ago in reply to techiecs
    Dear techiecs,
    glad to give a update:
    I created the skill with your help(axlFilmCreate ) and it works as i expect. Many thanks again for your help and support.
    Many thanks again and best Regards
    Moyan
