  3. axlOpenDesignForBatch( works differently between 22.1 and...
  • State Verified Answer
  • Subscribers 22
  • Views 827
axlOpenDesignForBatch( works differently between 22.1 and 25.1 ( appears broken )
Mhawley1
Mhawley1 4 months ago
I just found something interesting today and would be nice for someone to test.
It would seem like axlOpenDesignForBatch( no longer runs without a save prompt in 25.1 under the WF mode . Can someone try this out . Try out the example and see if you can batch open two dra's without the prompt coming up .
axlOpenDesignForBatch("u.dra" "wf")  ( tested in 25.1 S 30 )
Should I make a ticket ?
  • Mhawley1
    Mhawley1 4 months ago +1 verified
    Nope , nevermind . I am an idiot . There is a variable in preferences that needs to be set true for that command to work with no prompts . It called NOCONFIRM . Once that is checked the skill works as…
  • Mhawley1
    +1 Mhawley1 4 months ago
    It called NOCONFIRM . Once that is checked the skill works as expected .
