  3. How to merge excel cell in Allgero SKILL using axlSpreadsheet...
  • State Verified Answer
  • Subscribers 20
  • Views 1349
How to merge excel cell in Allgero SKILL using axlSpreadsheet API
SK202607205032
SK202607205032 3 months ago
I just using axlSpreadsheetInit() to write excel file, but I don't know how to merge cell,example as the picture below.
Is there any suggestion? Thanks a lot.
  • Hoangkhoipcb
    Hoangkhoipcb 3 months ago +1 verified
    Hi SK, According to my experience, Allegro SKILL does not support merging cells like Microsoft Excel does. My recommendation is to explore the Allegro SKILL plugin and integrate it with the XlsxWriter…
  • Hoangkhoipcb
    +1 Hoangkhoipcb 3 months ago
    Hi SK,
    According to my experience, Allegro SKILL does not support merging cells like Microsoft Excel does. My recommendation is to explore the Allegro SKILL plugin and integrate it with the XlsxWriter library to generate a native Excel file that fully supports features such as merged cells.
    BR,
    HoangKhoi
  • BT202507156313
    0 BT202507156313 3 months ago
    Merging cells in an XML file can be done quite easily using the following approach:
    • Read the XML file again using the infile function.
    • Iterate through each row and store the row data.
    • When reaching the target row and cell to be merged, add MergeAcross according to the Excel XML syntax.
    • Continue reading the file until reaching the last line.
    • Save the modified file.
    Luan
  • SK202607205032
    0 SK202607205032 1 month ago in reply to Hoangkhoipcb
    Hi HoangKhoi,
    I successfully import .json and exported the .xlsx file in Python. However, after converting the Python script into an .exe file and using it within the skill, the export failed(didn't find the .xlsx file). Is there any example?thanks a lot!
  • Hoangkhoipcb
    0 Hoangkhoipcb 28 days ago in reply to SK202607205032
    Hi SK202607205032
    Run the code in test.py without using a .exe file.
    import xlsxwriter
    workbook = xlsxwriter.Workbook("output.xlsx")
    worksheet = workbook.add_worksheet()
    worksheet.write("A1", "Hello")
    worksheet.write("B1", "World")
    worksheet.write("A2", 100)
    workbook.close()
    type this code in cmd Allegro
    skill ipcBeginProcess("python test.py" "" "CallbackFun"); can remove CallbackFun
    BR,
    HoangKhoi
