  3. How to remove an element from a group without deleting or...
  • Subscribers 20
  • Views 511
How to remove an element from a group without deleting or disbanding the group using SKILL
JuanCR
JuanCR 3 months ago
Let's say you have a specific group of elements in a brd file and you want to remove one element from this group. How can you remove it without disbanding the group or deleting the element?
The SKILL function axlDBRemoveGroupObjects can be used to remove database objects from the specified group. Group members, though removed, are not deleted.
axlDBRemoveGroupObjects(o_group lo_members) ⇒ t/nil
Arguments:
  • o_group: The database ID of the group from which objects will be removed.
  • o_members: A list of database objects to be removed from the group. A single database ID can be substituted for a list.
This function removes the selected objects (lo_members) from the specified group (o_group). Neither the group nor the member is deleted.
The following SKILL code can be used to remove an object from multiple groups at the same time:
procedure( removeObjectFromGroup()
    let((objects_dbid group_dbd group_bibliotec elemnt group)
        axlSetFindFilter(?enabled list("all") ?onButtons list("noall" "symbols" "shapes"))
        axlClearSelSet()
        axlSingleSelectPoint()
        objects_dbid=axlGetSelSet()
        group_bibliotec=makeTable("groups" nil)
        foreach(elemnt objects_dbid
            foreach(group elemnt->parentGroups
                if(group then group_bibliotec[group]=append(group_bibliotec[group] list(elemnt)))
        foreach(group_dbd group_bibliotec
                axlDBRemoveGroupObjects(group_dbd group_bibliotec[group_dbd])
Explanation of the SKILL code:
The first step in the removeObjectFromGroup() function is to set the Find filter:
axlSetFindFilter(?enabled list("noall" "symbols" "shapes") ?onButtons list("noall" "symbols" "shapes"))
This will decide what kind of objects you can select on the canvas. In this case, from all possible objects, only “symbols” and “shapes” are selectable; “symbols” and “shapes” are already set to "on".
Then, selection of the objects can be done using the following function. Note that there are many functions that let you select objects in different ways. You can read more about it in Allegro SKILL Reference 22.1 > Select and Finds Functions.
This function allows you to select a single point on the screen. When this function is called, it will wait for an action from the user to pick a point. Everything that matches the Find filter will be selected. To get all objects selected, use:
The variable objects_dbid can have multiple objects, and each one of these objects can belong to a different group. To classify which object belongs to each group, use a table (group_bibliotec):
In the below code, foreach is used to pass by each element of the objects_dbid list. Then, foreach is used again to pass by all parent groups that this element can belong to. The code then checks if the object does belong to any group. If it does, the current element is appended to the group_bibliotec with the matching key.
To remove the components from the groups:
foreach(group_dbd list_groups_dbid
      axlDBRemoveGroupObjects(group_dbd objects_dbid)
