  3. Skill script for checking BGA pitch
  • Subscribers 22
  • Views 1239
SG20260713408
SG20260713408 2 months ago
This is a skill for inspecting the pitch of BGAs on a board.
If you know of a more concise and elegant code than this, please let me know. (SKILL++, OOP...)
Thank you.
Note: On September 25, 2026,
          27.0 was changed to 270.0
* Tool Name : min_pitch_bga (Enhanced Version)
* Description : Automatically checks the minimum pitch of BGA components to prevent fine-pitch routing defects.
* Features :
* 1. Support multiple symbol filtering cases (Property, SymType)
* 2. Performance Optimization: Auto-bounding box shrinkage for
* high pin-count components to prevent computation lag.
* 3. Auto-sorting and reporting with an interactive .log viewer.
* Command : min_pitch_bga [Optional Pitch Value, default "0.5"]
* To change the pitch value, simply apply the desired pitch value after the command. (min_pitch_bga 1.0 or min_pitch_bga 0.5 .......)
axlCmdRegister("min_pitch_bga" 'min_pitch_bga ?cmdType "interactive")
procedure(min_pitch_bga(@optional (argu_bga_pitch "0.5") "S")
let((min_bga_pitch symbols loop sym_pins_locs obj1 objPairs pitch_datas min_pitch_data
pair_count var_x var_y delta_x delta_y refdes sym_xy layer sym_rot all_x_loc all_y_loc min_x min_y max_x max_y sym_pins total_results)
min_bga_pitch = atof(argu_bga_pitch)
when(min_bga_pitch
;;Comment : Please select and use the case that fits the situation.
;;Comment(Case1) : Use when a symbol(footprint) is given a property name("DFA_DEV_CLASS") and a property value("bga").
;; Property values are entered by the user, so they are case-sensitive.
symbols = foreach(mapcan item axlSelectByProperty("symdef" "DFA_DEV_CLASS" "bga") ~> instances item) ;; Use if applicable to Case 1
;;symbols = foreach(mapcan item axlSelectByProperty("symdef" "DFA_DEV_CLASS" "bg*" t) ~> instances item) ;; Use if applicable to Case 1
;;symbols = foreach(mapcan item axlSelectByProperty("symdef" "REF_PATTERN_NAME" "BGA*" t) ~> instances item) ;; Use if applicable to Case 1
;; Comment(Case2) : The name given when generating the symbol(footprint).
;; In other words, when the symbol name(footprint name) starts with "BGAXXXXXXXX_XXX_XXX"
;;symbols = axlSelectByName("SYMTYPE" "BGA*" t) ;; Use if applicable to Case 2, Delete ";;" and use
axlClearSelSet()
if(symbols then
foreach(symbol symbols
loop = t
sym_rot = nil
sym_pins = nil
sym_pins_locs = nil
all_x_loc = nil
all_y_loc = nil
objPairs = nil
pitch_datas = nil
min_pitch_data = nil
pair_count = nil
var_x = nil
var_y = nil
delta_x = nil
delta_y = nil
sym_xy = symbol -> xy
refdes = symbol -> refdes
unless(refdes refdes = "No RefDes")
layer = if(symbol -> isMirrored then "BOTTOM" else "TOP")
sym_pins = setof(e symbol -> pins e -> number != "" || e -> isMech != t)
when(sym_pins && length(sym_pins) > 1
sym_rot = symbol -> rotation
if(axlGeoEqual(sym_rot 0.0) || axlGeoEqual(sym_rot 90.0) || axlGeoEqual(sym_rot 180.0) || axlGeoEqual(sym_rot 270.0) then      ;;Changed here.
sym_pins_locs = sym_pins ~> xy
else
foreach(sym_pin sym_pins
sym_pin_xy = sym_pin -> xy
rot_pin = axlGeoRotatePt(minus(sym_rot) car(sym_pin_xy):cadr(sym_pin_xy) car(sym_xy):cadr(sym_xy))
sym_pins_locs = cons(rot_pin sym_pins_locs)
all_x_loc = foreach(mapcar item sym_pins_locs car(item))
all_y_loc = foreach(mapcar item sym_pins_locs cadr(item))
var_x = apply('min all_x_loc)
sym_x = apply('max all_x_loc)
var_y = apply('min all_y_loc)
sym_y = apply('max all_y_loc)
delta_x = abs(sym_x - var_x)
delta_y = abs(sym_y - var_y)
sym_xy = list((sym_x - (delta_x / 2)) (sym_y - (delta_y / 2)))
delta_x = delta_x / 30
delta_y = delta_y / 30
sym_pins_locs = setof(e sym_pins_locs axlIsPointInsideBox(e list(sym_xy list(var_x var_y))))
when(length(sym_pins_locs) > 1
pair_count = (length(sym_pins_locs) * (length(sym_pins_locs) - 1)) / 2
when(pair_count > 1500
while(loop
var_x = var_x + delta_x
var_y = var_y + delta_y
delta_x = (car(sym_xy) - var_x) / 30
delta_y = (cadr(sym_xy) - var_y) / 30
when(pair_count < 1500 loop = nil)
when(sym_pins_locs
while(sym_pins_locs
obj1 = car(sym_pins_locs)
sym_pins_locs = cdr(sym_pins_locs)
foreach(obj2 sym_pins_locs objPairs = cons(list(obj1, obj2), objPairs))
when(objPairs
foreach(objPair objPairs
pitch_datas = cons(axlDistance(car(objPair) cadr(objPair)) pitch_datas)
min_pitch_data = car(sort(pitch_datas 'lessp))
when(min_pitch_data
when(min_pitch_data < min_bga_pitch
axlHighlightObject(symbol)
total_results = cons(list(layer refdes min_pitch_data symbol -> xy symbol -> name) total_results)
total_results = reverse(sortcar(total_results 'axlStrcmpAlpNum))
MPB_Create_log_File(total_results min_bga_pitch)
else
printf("###### BGA cannot be found. !! ######\n")
procedure(MPB_Create_log_File(total_results min_bga_pitch)
let((err_count Date Min_Pitch_BGA_Log_File)
err_count = 0
Date = (getCurrentTime)
Date = parseString(Date " ")
Date = strcat(nth(3 Date) " " nth(0 Date) " " nth(1 Date) " " nth(2 Date))
Min_Pitch_BGA_Log_File = outfile("./Min_Pitch_BGA.log" "w")
fprintf(Min_Pitch_BGA_Log_File "\nDATE : %s\n" Date)
fprintf(Min_Pitch_BGA_Log_File "\nTarGet Pitch : %f\n" min_bga_pitch)
fprintf(Min_Pitch_BGA_Log_File "\nSyntax : nIndex, Layer, RefDes, Pitch, Symbol_XY, Symbol_Name\n")
fprintf(Min_Pitch_BGA_Log_File "\n=========================================================================\n")
if(length(total_results) == 0 then
fprintf(Min_Pitch_BGA_Log_File "\n Total Error Count = 0\n")
else
fprintf(Min_Pitch_BGA_Log_File "\nIndex, Layer, RefDes, Pitch, Symbol_XY, Symbol_Name\n")
foreach(total_result total_results
err_count = ++err_count
fprintf(Min_Pitch_BGA_Log_File "\n%d, %s, %s, %f, %L, %s\n" err_count nth(0 total_result) nth(1 total_result) nth(2 total_result) nth(3 total_result) nth(4 total_result))
fprintf(Min_Pitch_BGA_Log_File "\n Total Error Count = %d.\n" err_count)
close(Min_Pitch_BGA_Log_File)
axlShell("viewlog ./Min_Pitch_BGA.log")
  • SG20260713408
    SG20260713408 2 months ago in reply to TL202608111936
    I would love to see your code whenever you have time to test it.
    I'm really looking forward to your approach.
    thank you.
