  3. Skill script for checking BGA pitch
  • Subscribers 22
  • Views 1238
SG20260713408
SG20260713408 2 months ago
This is a skill for inspecting the pitch of BGAs on a board.
If you know of a more concise and elegant code than this, please let me know. (SKILL++, OOP...)
Thank you.
Note: On September 25, 2026,
          27.0 was changed to 270.0
* Tool Name : min_pitch_bga (Enhanced Version)
* Description : Automatically checks the minimum pitch of BGA components to prevent fine-pitch routing defects.
* Features :
* 1. Support multiple symbol filtering cases (Property, SymType)
* 2. Performance Optimization: Auto-bounding box shrinkage for
* high pin-count components to prevent computation lag.
* 3. Auto-sorting and reporting with an interactive .log viewer.
* Command : min_pitch_bga [Optional Pitch Value, default "0.5"]
* To change the pitch value, simply apply the desired pitch value after the command. (min_pitch_bga 1.0 or min_pitch_bga 0.5 .......)
axlCmdRegister("min_pitch_bga" 'min_pitch_bga ?cmdType "interactive")
procedure(min_pitch_bga(@optional (argu_bga_pitch "0.5") "S")
let((min_bga_pitch symbols loop sym_pins_locs obj1 objPairs pitch_datas min_pitch_data
pair_count var_x var_y delta_x delta_y refdes sym_xy layer sym_rot all_x_loc all_y_loc min_x min_y max_x max_y sym_pins total_results)
min_bga_pitch = atof(argu_bga_pitch)
when(min_bga_pitch
;;Comment : Please select and use the case that fits the situation.
;;Comment(Case1) : Use when a symbol(footprint) is given a property name("DFA_DEV_CLASS") and a property value("bga").
;; Property values are entered by the user, so they are case-sensitive.
symbols = foreach(mapcan item axlSelectByProperty("symdef" "DFA_DEV_CLASS" "bga") ~> instances item) ;; Use if applicable to Case 1
;;symbols = foreach(mapcan item axlSelectByProperty("symdef" "DFA_DEV_CLASS" "bg*" t) ~> instances item) ;; Use if applicable to Case 1
;;symbols = foreach(mapcan item axlSelectByProperty("symdef" "REF_PATTERN_NAME" "BGA*" t) ~> instances item) ;; Use if applicable to Case 1
;; Comment(Case2) : The name given when generating the symbol(footprint).
;; In other words, when the symbol name(footprint name) starts with "BGAXXXXXXXX_XXX_XXX"
;;symbols = axlSelectByName("SYMTYPE" "BGA*" t) ;; Use if applicable to Case 2, Delete ";;" and use
axlClearSelSet()
if(symbols then
foreach(symbol symbols
loop = t
sym_rot = nil
sym_pins = nil
sym_pins_locs = nil
all_x_loc = nil
all_y_loc = nil
objPairs = nil
pitch_datas = nil
min_pitch_data = nil
pair_count = nil
var_x = nil
var_y = nil
delta_x = nil
delta_y = nil
sym_xy = symbol -> xy
refdes = symbol -> refdes
unless(refdes refdes = "No RefDes")
layer = if(symbol -> isMirrored then "BOTTOM" else "TOP")
sym_pins = setof(e symbol -> pins e -> number != "" || e -> isMech != t)
when(sym_pins && length(sym_pins) > 1
sym_rot = symbol -> rotation
if(axlGeoEqual(sym_rot 0.0) || axlGeoEqual(sym_rot 90.0) || axlGeoEqual(sym_rot 180.0) || axlGeoEqual(sym_rot 270.0) then      ;;Changed here.
sym_pins_locs = sym_pins ~> xy
else
foreach(sym_pin sym_pins
sym_pin_xy = sym_pin -> xy
rot_pin = axlGeoRotatePt(minus(sym_rot) car(sym_pin_xy):cadr(sym_pin_xy) car(sym_xy):cadr(sym_xy))
sym_pins_locs = cons(rot_pin sym_pins_locs)
all_x_loc = foreach(mapcar item sym_pins_locs car(item))
all_y_loc = foreach(mapcar item sym_pins_locs cadr(item))
var_x = apply('min all_x_loc)
sym_x = apply('max all_x_loc)
var_y = apply('min all_y_loc)
sym_y = apply('max all_y_loc)
delta_x = abs(sym_x - var_x)
delta_y = abs(sym_y - var_y)
sym_xy = list((sym_x - (delta_x / 2)) (sym_y - (delta_y / 2)))
delta_x = delta_x / 30
delta_y = delta_y / 30
sym_pins_locs = setof(e sym_pins_locs axlIsPointInsideBox(e list(sym_xy list(var_x var_y))))
when(length(sym_pins_locs) > 1
pair_count = (length(sym_pins_locs) * (length(sym_pins_locs) - 1)) / 2
when(pair_count > 1500
while(loop
var_x = var_x + delta_x
var_y = var_y + delta_y
delta_x = (car(sym_xy) - var_x) / 30
delta_y = (cadr(sym_xy) - var_y) / 30
when(pair_count < 1500 loop = nil)
when(sym_pins_locs
while(sym_pins_locs
obj1 = car(sym_pins_locs)
sym_pins_locs = cdr(sym_pins_locs)
foreach(obj2 sym_pins_locs objPairs = cons(list(obj1, obj2), objPairs))
when(objPairs
foreach(objPair objPairs
pitch_datas = cons(axlDistance(car(objPair) cadr(objPair)) pitch_datas)
min_pitch_data = car(sort(pitch_datas 'lessp))
when(min_pitch_data
when(min_pitch_data < min_bga_pitch
axlHighlightObject(symbol)
total_results = cons(list(layer refdes min_pitch_data symbol -> xy symbol -> name) total_results)
total_results = reverse(sortcar(total_results 'axlStrcmpAlpNum))
MPB_Create_log_File(total_results min_bga_pitch)
else
printf("###### BGA cannot be found. !! ######\n")
procedure(MPB_Create_log_File(total_results min_bga_pitch)
let((err_count Date Min_Pitch_BGA_Log_File)
err_count = 0
Date = (getCurrentTime)
Date = parseString(Date " ")
Date = strcat(nth(3 Date) " " nth(0 Date) " " nth(1 Date) " " nth(2 Date))
Min_Pitch_BGA_Log_File = outfile("./Min_Pitch_BGA.log" "w")
fprintf(Min_Pitch_BGA_Log_File "\nDATE : %s\n" Date)
fprintf(Min_Pitch_BGA_Log_File "\nTarGet Pitch : %f\n" min_bga_pitch)
fprintf(Min_Pitch_BGA_Log_File "\nSyntax : nIndex, Layer, RefDes, Pitch, Symbol_XY, Symbol_Name\n")
fprintf(Min_Pitch_BGA_Log_File "\n=========================================================================\n")
if(length(total_results) == 0 then
fprintf(Min_Pitch_BGA_Log_File "\n Total Error Count = 0\n")
else
fprintf(Min_Pitch_BGA_Log_File "\nIndex, Layer, RefDes, Pitch, Symbol_XY, Symbol_Name\n")
foreach(total_result total_results
err_count = ++err_count
fprintf(Min_Pitch_BGA_Log_File "\n%d, %s, %s, %f, %L, %s\n" err_count nth(0 total_result) nth(1 total_result) nth(2 total_result) nth(3 total_result) nth(4 total_result))
fprintf(Min_Pitch_BGA_Log_File "\n Total Error Count = %d.\n" err_count)
close(Min_Pitch_BGA_Log_File)
axlShell("viewlog ./Min_Pitch_BGA.log")
  • Elecguy
    Elecguy 2 months ago
    Just took a quick look at it and it seems good. Any special conditions for the board where it should be used?
  • SG20260713408
    SG20260713408 2 months ago in reply to Elecguy
    There are no special conditions.
    I uploaded the relevant code a while ago, but I have improved the parts that were lacking and uploaded it again.
    I was just curious to see what ideas others might have.
    Thank you.
  • TL202608111936
    TL202608111936 2 months ago
    For BGA packages with a large number of pins, identifying all pin pairs and measuring the distance between each pair can significantly slow down the code. I suggest dividing the BGA pins into a grid based on a predefined pitch. This way, I think we can reduce the number of distance measurements by approximately 50%.
    Luan
  • SG20260713408
    SG20260713408 2 months ago in reply to TL202608111936
    Thank you for sharing your thoughts.
    Since the pitch and pin arrangement of BGAs are not all identical, it is difficult to grid them based on the input pitch.
    Thank you.
  • TL202608111936
    TL202608111936 2 months ago in reply to SG20260713408
    Although I haven't written the code to test my idea yet, I still stand by the idea.
    Based on the initial user pitch and the pin list, I will sort the pin list by rows and columns, with each row/column separated by one user pitch and within a predefined tolerance. This will give me a matrix of the pin coordinates by row and column.
    Then, within each row and column, I will sort the pins by X or Y coordinate. Finally, I will measure the distance between two consecutive coordinates in each row or column to find gaps that are smaller than the user pitch.
    This approach should significantly reduce the number of measurements compared with the current method.
    Finally, I will filter out the pins that do not satisfy the row and column conditions described above. These pins can be considered an "exception pin list" and will be checked separately using the old method, which scans the area to find the pitch.
    If I have time, I will try coding this approach to see whether the idea is actually feasible.
    Luan
