  3. Extract areas on the FPCB that do not contain arcs.
  • Replies 8
  • Subscribers 19
  • Views 457
SG20260713408
SG20260713408 11 days ago
When designing an FPCB (Flexible Printed Circuit Board), corners are often rounded using arcs.
This script extracts the coordinates of connection points between cline segments where no arc has been generated.
In other words, assuming that all corners should be rounded with arcs, it identifies the locations where arcs are missing.
Therefore, you can verify the design by running the test after applying arcs to all corners.
GoodBye~~
axlCmdRegister("find_napoc" 'Find_No_Arc_Point_Of_Clines ?cmdType "interactive")
procedure(Find_No_Arc_Point_Of_Clines()
let((theta_lists check_list check_lists cline_seg_count all_cline_seg_count
sel_nets sel_net_name sel_net_branches sel_net_branches_childrens pin_via_dbs cline_dbs
cline_db_segments first_seg_in_pin_via_value layer first_startend
first_start_xy first_end_xy first_find_pin_via_db first_find_pin_via_db_poly first_start_xy_in_db_result first_end_xy_in_db_result
last_startend last_start_xy last_end_xy last_find_pin_via_db last_find_pin_via_db_poly
segment_objtype segment_layer segment_start_end_xy segment_start_xy segment_start_x segment_start_y
segment_end_xy segment_end_x segment_end_y delta_x delta_y
theta theta_lists seg_start_xy_in_first_db_result seg_start_xy_in_last_db_result)
theta_lists = list(nil)
check_lists = list()
axlClearSelSet()
sel_nets = axlDBGetDesign() -> nets
foreach(sel_net sel_nets
sel_net_name = sel_net -> name
sel_net_branches = sel_net -> branches
when(sel_net_branches
foreach(sel_net_branche sel_net_branches
sel_net_branches_childrens = sel_net_branche -> children
pin_via_dbs = setof(db sel_net_branches_childrens db -> objType == "pin" || db -> objType == "via")
cline_dbs = setof(db sel_net_branches_childrens db -> objType == "path")
when(cline_dbs
foreach(cline_db cline_dbs
cline_db_segments = cline_db -> segments
when(cline_db_segments
cline_db_segments_length = length(cline_db_segments)
cline_seg_count = 0
all_cline_seg_count = 0
first_seg_in_pin_via_value = nil
layer = car(cline_db_segments) -> layer
first_startend = car(cline_db_segments) -> startEnd
first_start_xy = car(first_startend)
first_end_xy = cadr(first_startend)
first_find_pin_via_db = car(setof(db pin_via_dbs axlGeoPointsEqual(db -> xy first_start_xy)))
if(first_find_pin_via_db then
first_find_pin_via_db_poly = car(axlPolyFromDB(first_find_pin_via_db ?layer layer ?padType 'REGULAR))
first_start_xy_in_db_result = axlGeoPointInShape(first_start_xy first_find_pin_via_db_poly)
first_end_xy_in_db_result = axlGeoPointInShape(first_end_xy first_find_pin_via_db_poly)
when(first_start_xy_in_db_result && first_end_xy_in_db_result first_seg_in_pin_via_value = t)
else
first_find_pin_via_db_poly = nil
last_startend = lastelem(cline_db_segments) -> startEnd
last_start_xy = car(last_startend)
last_end_xy = cadr(last_startend)
last_find_pin_via_db = car(setof(db pin_via_dbs axlGeoPointsEqual(db -> xy last_end_xy)))
if(last_find_pin_via_db then
last_find_pin_via_db_poly = car(axlPolyFromDB(last_find_pin_via_db ?layer layer ?padType 'REGULAR))
else
last_find_pin_via_db_poly = nil
foreach(segment cline_db_segments
cline_seg_count = ++cline_seg_count
all_cline_seg_count = ++all_cline_seg_count
segment_objtype = segment -> objType
segment_layer = cadr(parseString(segment -> layer "/"))
segment_start_end_xy = segment -> startEnd
segment_start_xy = car(segment_start_end_xy)
segment_start_x = car(segment_start_xy)
segment_start_y = cadr(segment_start_xy)
segment_end_xy = cadr(segment_start_end_xy)
segment_end_x = car(segment_end_xy)
segment_end_y = cadr(segment_end_xy)
delta_x = segment_start_x - segment_end_x
delta_y = segment_start_y - segment_end_y
if(oddp(cline_seg_count) then
theta = axlRadToDeg(atan2(delta_y delta_x))
theta_lists = cons(theta theta_lists)
when(all_cline_seg_count == 1 && first_seg_in_pin_via_value cline_seg_count = 1)
when(segment_objtype == "arc" cline_seg_count = 0)
if(zerop(cline_seg_count) && evenp(cline_seg_count) then
else
when(!zerop(cline_seg_count) && evenp(cline_seg_count)
seg_start_xy_in_first_db_result = axlGeoPointInShape(segment_start_xy first_find_pin_via_db_poly)
;;seg_end_xy_in_first_db_result = axlGeoPointInShape(segment_end_xy first_find_pin_via_db_poly)
seg_start_xy_in_last_db_result = axlGeoPointInShape(segment_start_xy last_find_pin_via_db_poly)
;;seg_end_xy_in_last_db_result = axlGeoPointInShape(segment_end_xy last_find_pin_via_db_poly)
before_theta = car(theta_lists)
if(segment_objtype != "arc" then
if(axlGeoEqual(before_theta theta) then
cline_seg_count = 1
else
if(seg_start_xy_in_first_db_result || seg_start_xy_in_last_db_result then
cline_seg_count = 1
else
check_list = list(segment_layer segment_start_xy sel_net_name)
check_lists = cons(check_list check_lists)
cline_seg_count = 1
else
cline_seg_count = 0
theta_lists = list(car(theta_lists))
check_lists = sortcar(check_lists 'axlStrcmpAlpNum)
if(zerop(length(check_lists)) then
;;printf("### Error Count = 0 ###\n")
axlUIConfirm("Error Count Zero(0)" 'info)
else
Create_Find_No_Arc_Point_Of_Clines_log_File(check_lists)
procedure(Create_Find_No_Arc_Point_Of_Clines_log_File(checking_result_infor_lists)
let((total_all_error_count Date)
total_all_error_count = 0
Date = (getCurrentTime)
Date = parseString(Date " ")
Date = strcat(nth(3 Date) " " nth(0 Date) " " nth(1 Date) " " nth(2 Date))
Find_No_Arc_Point_Of_Clines_Log_File = outfile("./Find_No_Arc_Point_Of_Clines.log" "w")
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "\nDATE : %s\n" Date)
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "\nSyntax : Layer, Point_XY, Net_Name\n")
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "\n=========================================================================\n")
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "\n ## REPORT OF NO ARC BETWEEN TWO CLINE SEGS ##\n\n")
foreach(checking_result_infor_list checking_result_infor_lists
total_all_error_count = ++total_all_error_count
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "%d.%s, %L, %s\n" total_all_error_count car(checking_result_infor_list) cadr(checking_result_infor_list) caddr(checking_result_infor_list))
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "\n=========================================================================\n\n")
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "Total Error Count = %d ea.\n" total_all_error_count)
close(Find_No_Arc_Point_Of_Clines_Log_File)
axlShell("viewlog ./Find_No_Arc_Point_Of_Clines.log")
  • Hoangkhoipcb
    Hoangkhoipcb 5 days ago +1
    Hi SG20260713408 , I tested your code, and it works well for me. I've made a shorter version of the code for you to reference. axlCmdRegister ( "create_arc_chk" 'create_arc_chk ) ( defun create_arc_chk…
  • Hoangkhoipcb
    Hoangkhoipcb 4 days ago in reply to SG20260713408
    Hi SG,
  • SG20260713408
    SG20260713408 3 days ago in reply to Hoangkhoipcb
    Hi Hoangkhoipcb
    I think other users might need your feature, so I am uploading the modified code.
    However, the UI window is small.
    Thank you.
    1. Modified to allow checking of individual layers or all layers.
    2. When the window appears after execution:
    3. Select the layer you wish to check and click the OK button.
    - All_Layer : Checks clines on all layers.
    - Etc          : Checks clines only on the specific layer.
    4. Clicking the Cancel button stops the operation.
    axlCmdRegister("create_arc_chk" 'create_arc_chk)
    (defun create_arc_chk ()
    (let ()
    prog(()
    all_layers = append(list("All_Layer") axlSubclassRoute(?field 'isEtch))
    sel_layer = nth(axlUIMultipleChoice("Select a Layer" all_layers "All Etch Layer") all_layers)
    when(sel_layer
    if(sel_layer == "All_Layer" then
    axlSetFindFilter(?enabled '("noall" "CLINES" "INVISIBLE") ?onButtons '("all"))
    axlAddSelectAll()
    clines = axlGetSelSet()
    else
    axlVisibleDesign(nil)
    axlVisibleLayer(strcat("ETCH/" sel_layer) t)
    axlVisibleLayer(strcat("PIN/" sel_layer) t)
    axlVisibleLayer(strcat("VIA CLASS/" sel_layer) t)
    axlVisibleLayer("BOARD GEOMETRY/OUTLINE" t)
    axlVisibleUpdate(t)
    axlSetFindFilter(?enabled '("noall" "CLINES") ?onButtons '("all"))
    axlAddSelectAll()
    ) ;;if sel_layer
    axlClearSelSet()
    tmp_list = nil
    seg_list = nil
    Out_file = outfile("create_arc_chk.log" "w")
    fprintf(Out_file "%-5s %-7s %-10s %s\n" "No" "Angle" "Layer" "Location" )
    foreach(cline clines
    segs = cline->segments
    foreach(seg segs
    if(length(member(seg segs)) > 1 then
    next_seg = cadr(member(seg segs))
    if(seg->xy == nil && next_seg->xy == nil then
    ol = axl_ol_ol2(seg->startEnd next_seg->startEnd)
    if(member(car(ol) tmp_list) == nil then
    angle = abs(axlRadToDeg(axlGeoAngleBetweenLines(seg->startEnd next_seg->startEnd)))
    if(axlGeoEqual(angle 0.0) || axlGeoEqual(angle 180.0) then
    else
    push(car(ol) tmp_list)
    fprintf(Out_file "%-5d %-7.2f %-10s %L\n" length(tmp_list) angle cadr(parseString(seg->layer "/")) car(ol) )
    push(seg seg_list)
    push(next_seg seg_list)
    close(Out_file)
    if(length(tmp_list) > 0 then
    axlHighlightObject(seg_list)
    axlUIViewFileCreate("create_arc_chk.log" "Arc Segments Check" nil)
    printf("Errors : %d\n" length(tmp_list))
  • Hoangkhoipcb
    Hoangkhoipcb 3 days ago in reply to SG20260713408
    Thank you! I completely agree.
