  3. Extract areas on the FPCB that do not contain arcs.
  • Replies 8
  • Subscribers 21
  • Views 1155
SG20260713408
SG20260713408 1 month ago
When designing an FPCB (Flexible Printed Circuit Board), corners are often rounded using arcs.
This script extracts the coordinates of connection points between cline segments where no arc has been generated.
In other words, assuming that all corners should be rounded with arcs, it identifies the locations where arcs are missing.
Therefore, you can verify the design by running the test after applying arcs to all corners.
GoodBye~~
axlCmdRegister("find_napoc" 'Find_No_Arc_Point_Of_Clines ?cmdType "interactive")
procedure(Find_No_Arc_Point_Of_Clines()
let((theta_lists check_list check_lists cline_seg_count all_cline_seg_count
sel_nets sel_net_name sel_net_branches sel_net_branches_childrens pin_via_dbs cline_dbs
cline_db_segments first_seg_in_pin_via_value layer first_startend
first_start_xy first_end_xy first_find_pin_via_db first_find_pin_via_db_poly first_start_xy_in_db_result first_end_xy_in_db_result
last_startend last_start_xy last_end_xy last_find_pin_via_db last_find_pin_via_db_poly
segment_objtype segment_layer segment_start_end_xy segment_start_xy segment_start_x segment_start_y
segment_end_xy segment_end_x segment_end_y delta_x delta_y
theta theta_lists seg_start_xy_in_first_db_result seg_start_xy_in_last_db_result)
theta_lists = list(nil)
check_lists = list()
axlClearSelSet()
sel_nets = axlDBGetDesign() -> nets
foreach(sel_net sel_nets
sel_net_name = sel_net -> name
sel_net_branches = sel_net -> branches
when(sel_net_branches
foreach(sel_net_branche sel_net_branches
sel_net_branches_childrens = sel_net_branche -> children
pin_via_dbs = setof(db sel_net_branches_childrens db -> objType == "pin" || db -> objType == "via")
cline_dbs = setof(db sel_net_branches_childrens db -> objType == "path")
when(cline_dbs
foreach(cline_db cline_dbs
cline_db_segments = cline_db -> segments
when(cline_db_segments
cline_db_segments_length = length(cline_db_segments)
cline_seg_count = 0
all_cline_seg_count = 0
first_seg_in_pin_via_value = nil
layer = car(cline_db_segments) -> layer
first_startend = car(cline_db_segments) -> startEnd
first_start_xy = car(first_startend)
first_end_xy = cadr(first_startend)
first_find_pin_via_db = car(setof(db pin_via_dbs axlGeoPointsEqual(db -> xy first_start_xy)))
if(first_find_pin_via_db then
first_find_pin_via_db_poly = car(axlPolyFromDB(first_find_pin_via_db ?layer layer ?padType 'REGULAR))
first_start_xy_in_db_result = axlGeoPointInShape(first_start_xy first_find_pin_via_db_poly)
first_end_xy_in_db_result = axlGeoPointInShape(first_end_xy first_find_pin_via_db_poly)
when(first_start_xy_in_db_result && first_end_xy_in_db_result first_seg_in_pin_via_value = t)
else
first_find_pin_via_db_poly = nil
last_startend = lastelem(cline_db_segments) -> startEnd
last_start_xy = car(last_startend)
last_end_xy = cadr(last_startend)
last_find_pin_via_db = car(setof(db pin_via_dbs axlGeoPointsEqual(db -> xy last_end_xy)))
if(last_find_pin_via_db then
last_find_pin_via_db_poly = car(axlPolyFromDB(last_find_pin_via_db ?layer layer ?padType 'REGULAR))
else
last_find_pin_via_db_poly = nil
foreach(segment cline_db_segments
cline_seg_count = ++cline_seg_count
all_cline_seg_count = ++all_cline_seg_count
segment_objtype = segment -> objType
segment_layer = cadr(parseString(segment -> layer "/"))
segment_start_end_xy = segment -> startEnd
segment_start_xy = car(segment_start_end_xy)
segment_start_x = car(segment_start_xy)
segment_start_y = cadr(segment_start_xy)
segment_end_xy = cadr(segment_start_end_xy)
segment_end_x = car(segment_end_xy)
segment_end_y = cadr(segment_end_xy)
delta_x = segment_start_x - segment_end_x
delta_y = segment_start_y - segment_end_y
if(oddp(cline_seg_count) then
theta = axlRadToDeg(atan2(delta_y delta_x))
theta_lists = cons(theta theta_lists)
when(all_cline_seg_count == 1 && first_seg_in_pin_via_value cline_seg_count = 1)
when(segment_objtype == "arc" cline_seg_count = 0)
if(zerop(cline_seg_count) && evenp(cline_seg_count) then
else
when(!zerop(cline_seg_count) && evenp(cline_seg_count)
seg_start_xy_in_first_db_result = axlGeoPointInShape(segment_start_xy first_find_pin_via_db_poly)
;;seg_end_xy_in_first_db_result = axlGeoPointInShape(segment_end_xy first_find_pin_via_db_poly)
seg_start_xy_in_last_db_result = axlGeoPointInShape(segment_start_xy last_find_pin_via_db_poly)
;;seg_end_xy_in_last_db_result = axlGeoPointInShape(segment_end_xy last_find_pin_via_db_poly)
before_theta = car(theta_lists)
if(segment_objtype != "arc" then
if(axlGeoEqual(before_theta theta) then
cline_seg_count = 1
else
if(seg_start_xy_in_first_db_result || seg_start_xy_in_last_db_result then
cline_seg_count = 1
else
check_list = list(segment_layer segment_start_xy sel_net_name)
check_lists = cons(check_list check_lists)
cline_seg_count = 1
else
cline_seg_count = 0
theta_lists = list(car(theta_lists))
check_lists = sortcar(check_lists 'axlStrcmpAlpNum)
if(zerop(length(check_lists)) then
;;printf("### Error Count = 0 ###\n")
axlUIConfirm("Error Count Zero(0)" 'info)
else
Create_Find_No_Arc_Point_Of_Clines_log_File(check_lists)
procedure(Create_Find_No_Arc_Point_Of_Clines_log_File(checking_result_infor_lists)
let((total_all_error_count Date)
total_all_error_count = 0
Date = (getCurrentTime)
Date = parseString(Date " ")
Date = strcat(nth(3 Date) " " nth(0 Date) " " nth(1 Date) " " nth(2 Date))
Find_No_Arc_Point_Of_Clines_Log_File = outfile("./Find_No_Arc_Point_Of_Clines.log" "w")
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "\nDATE : %s\n" Date)
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "\nSyntax : Layer, Point_XY, Net_Name\n")
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "\n=========================================================================\n")
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "\n ## REPORT OF NO ARC BETWEEN TWO CLINE SEGS ##\n\n")
foreach(checking_result_infor_list checking_result_infor_lists
total_all_error_count = ++total_all_error_count
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "%d.%s, %L, %s\n" total_all_error_count car(checking_result_infor_list) cadr(checking_result_infor_list) caddr(checking_result_infor_list))
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "\n=========================================================================\n\n")
fprintf(Find_No_Arc_Point_Of_Clines_Log_File "Total Error Count = %d ea.\n" total_all_error_count)
close(Find_No_Arc_Point_Of_Clines_Log_File)
axlShell("viewlog ./Find_No_Arc_Point_Of_Clines.log")
  • Hoangkhoipcb
    Hoangkhoipcb 1 month ago +1
    Hi SG20260713408 , I tested your code, and it works well for me. I've made a shorter version of the code for you to reference. axlCmdRegister ( "create_arc_chk" 'create_arc_chk ) ( defun create_arc_chk…
  • Elecguy
    Elecguy 1 month ago
    Interesting. But with no comments, no header, no instructions for the type of database it works on ... difficult to test
  • SG20260713408
    SG20260713408 1 month ago in reply to Elecguy
    I apologize.
    thank you
  • Hoangkhoipcb
    Hi SG20260713408,
    axlCmdRegister("create_arc_chk" 'create_arc_chk)
    (defun create_arc_chk ()
        (let ()
            prog(()
                axlSetFindFilter(?enabled '("noall" "CLINES" "INVISIBLE") ?onButtons '("all"))
                axlAddSelectAll()
                clines = axlGetSelSet()
                axlClearSelSet()
                tmp_list = nil
                seg_list = nil
                Out_file = outfile("create_arc_chk.log" "w")
                fprintf(Out_file "%-5s %-7s %-10s %s\n" "No" "Angle" "Layer" "Location" )
                foreach(cline clines
                    segs = cline->segments
                    foreach(seg segs
                        if(length(member(seg segs)) > 1 then
                            next_seg = cadr(member(seg segs))
                            if(seg->xy == nil && next_seg->xy == nil then
                                ol = axl_ol_ol2(seg->startEnd next_seg->startEnd)
                                if(member(car(ol) tmp_list) == nil then
                                    angle = abs(axlRadToDeg(axlGeoAngleBetweenLines(seg->startEnd next_seg->startEnd)))
                                    if(axlGeoEqual(angle 0.0) || axlGeoEqual(angle 180.0) then
                                    else
                                        push(car(ol) tmp_list)
                                        fprintf(Out_file "%-5d %-7.2f %-10s %L\n" length(tmp_list) angle cadr(parseString(seg->layer "/")) car(ol) )
                                        push(seg seg_list)
                                        push(next_seg seg_list)
                close(Out_file)
                if(length(tmp_list) > 0 then
                    axlHighlightObject(seg_list)
                    axlUIViewFileCreate("create_arc_chk.log" "Arc Segments Check" nil)
                    printf("Errors : %d\n" length(tmp_list))
    BR,
    HoangKhoi
  • SG20260713408
    SG20260713408 1 month ago in reply to Hoangkhoipcb
    Thanks, Hoangkhoipcb!
    I appreciate you sharing such concise code.
    I’m still studying to fully understand it,
    but I’ll take your code to heart; it will certainly help me think about writing code more concisely or elegantly.
    I’d love to ask for your email address,
    but given the nature of this community, I feel it’s not the right place for private conversations.
    I may lack expertise myself, but I notice that
    high-level script developers aren't providing answers here.
    Here are my personal thoughts on the code:
    1. I’m not sure why the "prog" function was used.
    2. There is no exception handling.
    - If a cline segment (or cline) is connected to a via, pin, or shape, there is no need to extract the point.
    3. The order of the results was determined for the sake of the next step.
    - The angle of the result doesn't matter; the designer just needs to be able to verify the result.
    (Though it would be useful for debugging purposes.)
    - If layers are mixed, unnecessary screen control operations are repeated.
    4. When I was a beginner, I used to put every function into a single block,
    but as the code grew longer, it became difficult to review or maintain, so I separated the log file generation.
    Ultimately, I decided to create separate functions for each specific task.
    thank you~~
  • Hoangkhoipcb
    Hoangkhoipcb 1 month ago in reply to SG20260713408
    Hi SG,
    Thank you very much for your thoughtful feedback! I really appreciate your comments.
    1. I use prog mainly out of habit. When validating multiple input parameters, I prefer to exit immediately if something is invalid.
    2. Exception handling depends on the design requirements. In my case, I intentionally don't allow those cases to be skipped.
    3. This SKILL was written quickly to check a design with around 50,000 clines on a single layer, so I allow the user to select the layer to process and saved time .
    4. I agree with you about separating functions. I would also suggest keeping the code as clear and concise as possible, including using shorter and more meaningful variable names where appropriate. This can make the code easier to read, review, and maintain.
    I hope you continue improving your SKILL development skills in future.
    If you'd like to contact me, hoangkhoipcb_@_gmail_com
    BR.
    HoangKhoi
