  3. SKILL: "*Error* if: too many arguments (missing then?)"...
  • Subscribers 21
  • Views 544
SKILL: "*Error* if: too many arguments (missing then?)" error on running "if" command
JuanCR
JuanCR 1 month ago
Check out the following statement:
if( order
        parameters = foreach( mapcar param order (get cdfgData param))
        parameters = (getq cdfgData parameters)
It seems a then keyword is missing, and the tool does not complain.
Now let's say you add a printf command like:
if( order
        printf("%L" parameters~>values)
In this case, you'll get the following error:
*Error* if: too many arguments (missing then?) -
(order (parameters = foreach(mapcar param order get(cdfgData param)))
(parameters = (cdfgData->parameters)) printf("%L" (parameters~>values)))
Why did you get this error, and how can you fix it? I'll show you:
Consider a simpler example. In the command line, type:
x = 2
Then enter this expression:
if( (x > 5) 1 0)
The tool will evaluate whether x > 5; if so, a "1" will be returned; otherwise, a "0" will be returned. Since 2 is less than 5, you will see the returned value as follows:
=> 0
This is because the "if" command falls into the following syntax:
if( g_condition g_thenExpression [ g_elseExpression ] )
Now, if a fourth argument is added ("3" in this case) as follows:
if( (x > 5) 1 0 3)
You will now see the following error:
*Error* if: too many arguments (missing then?) - ((x > 5) 1 0 3)
You get it because the 'compact' form of the if command is no longer applied. The syntax now becomes:
if( g_condition then g_thenExpr1 ... [ else g_elseExpr1 ... ] )
Thus, you need to add a "then" for a complete "if" command. If it is not present, the tool will generate an error message.
It is recommended to use the "then" and "else" keywords to avoid such syntax errors and reduce confusion. There are times when the 'compact' form is handy without the bloat of then...else, but it is generally recommended to add these keywords.
Check the SKILL Language Reference for details. Here's an excerpt from the input for the if conditional:
Description
This command selectively evaluates two groups of one or more expressions. The syntax is as follows:
    => g_result
The "if" form evaluates g_condition, typically a relational expression, and executes g_thenExpression if the condition is true (that is, its value is non-nil); otherwise, g_elseExpression is executed. The value returned by "if" is the value of the corresponding expression evaluated. The "if" form can therefore be used to evaluate expressions conditionally.
=> g_result
The second form of "if" uses the keywords "then" and "else" to group expressions into a conditional execution sequence. If the condition is true, the sequence of expressions between "then" and "else" (or the end of the if form) is evaluated, with the value of the last expression evaluated returned as the value of the form. If the condition is nil instead, the sequence of expressions following the "else" keyword (if any) is evaluated instead. Again, the value of the last expression evaluated is returned as the value of the form.
  • DavidJHutchins
    DavidJHutchins 1 month ago
    Why doesn't the sklint tool report these issues?
  • JuanCR
    JuanCR 1 month ago in reply to DavidJHutchins
    Hi David. I've tested this in sklint and it does report it. Where have you seen this not reported by it?
    For instance, I created a file with the example above if( (x > 5) 1 0 3) and when I run sklint I get this in the output file:
    NFO (STRICT): Using strict checking of global variables.
    ERROR (IF4): if.il, line 1 (abc) : 'then' and 'else' required in 'if' construct: if((x > 5) 1 0 ...)
    If you're getting a different result, let me know.
  • DavidJHutchins
    DavidJHutchins 1 month ago in reply to DavidJHutchins
    below is the 'if_test' procedure I added as a test:
    C:\Users\davidh\Documents>cat -n test.il | tail
        42  )
        43  procedure(if_test()
        44      let((parameters param)
        45          if( order
        46              parameters = foreach( mapcar param order (get cdfgData param))
        47              parameters = (getq cdfgData parameters)
        48          )
        49      )
        50  )
        51
    C:\Users\davidh\Documents>il_allegro
    > sklint(?file "test.il")
    Loading skillLint.cxt
    INFO (LoadFile): Loading file C:\Cadence\SPB_23.1\tools\sklint/rules/allegro_sklint.il...
    INFO (LoadFile): Loading file C:\Cadence\SPB_23.1\tools\sklint/rules/hi2ipc.il...
    INFO (LoadFile): Loading file C:\Cadence\SPB_23.1\tools\sklint/rules/ignore.il...
    INFO (LoadFile): Loading file C:\Cadence\SPB_23.1\tools\sklint/rules/ilMig.il...
    INFO (REP008): Program SKILL Lint started on Sep 29 08:43:09 2026.
    INFO (PREFIXES): Using prefixes: "none"
    INFO (STRICT): Using strict checking of global variables.
    SUGGEST (REMOVE1): test.il, line 23 (PadStackUsage) : Consider use of remq rather than remove: remove(name PadTable)
    HINT (NTH1): test.il, line 35 (parse_test) : Can replace call to nth with call to caddr: nth(2 parseString(param_line "<>"))
    UNUSED VAR (Unused): test.il, line 44 (if_test) : variable param does not appear to be referenced.
    UNUSED VAR (Unused): test.il, line 44 (if_test) : variable parameters does not appear to be referenced. (assigned only)
    INFO (VAR5): Unrecognized global variables:
    WARN GLOB (VAR8): cdfgData
    INFO (VAR): used:  in function if_test from file test.il, lines (47 46)
    WARN GLOB (VAR8): order
    INFO (VAR): used:  in function if_test from file test.il, lines (46 45)
    INFO (IQ): IQ score is 74 (best is 100).
    INFO (IQ1): IQ score is based on 0 error messages, 4 general warning messages, and 3 top level forms.
    INFO (REP110): Total enhancement     : 0.
    INFO (REP110): Total external global : 0.
    INFO (REP110): Total package global  : 0.
    INFO (REP110): Total warning global  : 2.
    INFO (REP110): Total error global    : 0.
    INFO (REP110): Total unused vars     : 2.
    INFO (REP110): Total next release    : 0.
    INFO (REP110): Total alert           : 0.
    INFO (REP110): Total hint            : 1.
    INFO (REP110): Total suggestion      : 1.
    INFO (REP110): Total internal alert  : 0.
    INFO (REP110): Total information     : 19.
    INFO (REP110): Total warning         : 0.
    INFO (REP110): Total error           : 0.
    INFO (REP110): Total internal error  : 0.
    INFO (REP110): Total fatal error     : 0.
    INFO (REP009): Program SKILL Lint finished on Sep 29 08:43:09 2026 with status PASS.
    t
    no error reported...
  • JuanCR
    Hi David,
    Yes, this "if" statement is correct. You're following the syntax "if( g_condition g_thenExpression [ g_elseExpression ] )"
    See above, in the post. If you replace the contents of the "if" by this:
    JuanCR said:
    if( order
    then you'll see that sklint will flag the error.
