  3. Extract areas on the FPCB that do not contain arcs.(Season2...
  • Subscribers 20
  • Views 388
Extract areas on the FPCB that do not contain arcs.(Season2)
SG20260713408
SG20260713408 1 month ago
Hello, everyone.
I am reposting this with the finalized code,
which builds upon the code shared by "Hoangkhoipcb".
Once again, I would like to thank "Hoangkhoipcb".
Note : Changed on 26Y/10M/16D (;; Change Here)
           Enabled execution by layer within APD.
*(26Y/09M/30D)
* Command   : create_arc_chk
* Function      : Checks for bent corners (sharp angles) without arcs on CLINES.
*                       Highlights detected segments and generates a report log.
* [How to Use]
* 1. Modified to allow checking of individual layers or all layers.
* 2. When the window appears after execution:
* 3. Select the layer you wish to check and click the OK button.
* - All_Layer : Checks clines on all layers.
* - Others     : Checks clines only on the specific layer.
* 4. Clicking the Cancel button stops the operation.
* Output File : create_arc_chk.log
axlCmdRegister("create_arc_chk" 'create_arc_chk)
(defun create_arc_chk ()
(let (all_layers sel_layer clines seg_list Out_file segs seg next_seg angle pt_corner error_count)
all_layers = append(list("All_Layer") axlSubclassRoute(?field 'isEtch))
sel_layer = nth(axlUIMultipleChoice("Select a Layer" all_layers "All Etch Layer") all_layers)
when(sel_layer
if(sel_layer == "All_Layer" then
axlSetFindFilter(?enabled '("noall" "CLINES" "INVISIBLE") ?onButtons '("all"))
axlAddSelectAll()
clines = axlGetSelSet()
else
axlVisibleDesign(nil)
axlVisibleLayer(strcat(axlMapClassName("ETCH") "/" sel_layer) t)  ;; Changed here.
axlVisibleLayer(strcat("PIN/" sel_layer) t)
axlVisibleLayer(strcat("VIA CLASS/" sel_layer) t)
axlVisibleLayer("BOARD GEOMETRY/OUTLINE" t)
axlVisibleUpdate(t)
axlSetFindFilter(?enabled '("noall" "CLINES") ?onButtons '("all"))
axlAddSelectAll()
axlClearSelSet()
seg_list = nil
error_count = 0
Out_file = outfile("create_arc_chk.log" "w")
fprintf(Out_file "%-5s %-7s %-10s %s\n" "No" "Angle" "Layer" "Location")
foreach(cline clines
segs = cline->segments
while(cdr(segs)
seg = car(segs)
next_seg = cadr(segs)
/* Proceed only if both segments are straight lines */
if(seg->xy == nil && next_seg->xy == nil then
/* Find the intersection point of two consecutive line segments */
if(axlGeoPointsEqual(car(seg->startEnd) car(next_seg->startEnd)) || axlGeoPointsEqual(car(seg->startEnd) cadr(next_seg->startEnd)) then
pt_corner = car(seg->startEnd)
else
pt_corner = cadr(seg->startEnd)
angle = abs(axlRadToDeg(axlGeoAngleBetweenLines(seg->startEnd next_seg->startEnd)))
if(!axlGeoEqual(angle 0.0) && !axlGeoEqual(angle 180.0) then
error_count = error_count + 1
fprintf(Out_file "%-5d %-7.2f %-10s %L\n" error_count angle cadr(parseString(seg->layer "/")) pt_corner)
seg_list = cons(seg seg_list)
seg_list = cons(next_seg seg_list)
segs = cdr(segs)
close(Out_file)
if(error_count > 0 then
axlHighlightObject(seg_list)
axlUIViewFileCreate("create_arc_chk.log" "Arc Segments Check" nil)
printf("### Errors : %d ###\n" error_count)
else
printf("### No arc-less corners found. ###\n")
  • Renu Vibha
    Renu Vibha 1 month ago
    Hi SG20260713408 Thank you very much for sharing the finalized code.
    Hoangkhoipcb thank you for sharing your expertise, and commitment to helping others make the community stronger every day!
