  2. Allegro X Scripting - TCL
  3. Net Group handling with OrCAD Capture Tcl/Tk command
  • Subscribers 14
  • Views 3303
ichliebedich
ichliebedich over 5 years ago
Hi All
my design have a lot of Net Group blocks, so it is difficult to find specific net group block with mouse
is there any function to find all net group names in my design on Capture?
if not, I want to create the Tcl/Tk code to make that I want.
although I refer to application note "OrCAD Capture TCL/Tk Extensions", It is difficult to find the function that I want because of too much information.
regard
  • steve
    steve over 5 years ago +1
    Try the Edit - Browse - Nets command, select the preferred mode then OK and you'll see a list of all the nets in the design. The netgroups are listed here as well.
  • ichliebedich
    ichliebedich over 5 years ago in reply to steve +1
    Thank you steve! but Can't I use find filter function? Ctrl + F is not work here to find net names
  • steve
    0 steve over 5 years ago
  • ichliebedich
    0 ichliebedich over 5 years ago in reply to steve
