  2. Allegro X Scripting - TCL
  3. Capture quit unexpectedly after delete DboWire instances...
  • Subscribers 14
  • Views 7443
Capture quit unexpectedly after delete DboWire instances in page by TCL script DeleteWire
ChunChang Wu
ChunChang Wu over 5 years ago
I tried using TCL to delete some DboWire instances which matches a criteria.
However, after I delete it by DboPage function DeleteWire, the schematic seems to have some invisible error which will lead Capture quit unexpectedly under some operations.
To be specific, after processing code below, Ctrl+F to find * (all) will make Capture shutdowm. For complicated schematic may even directly shutdown during the code processing.
set lStatus [DboState]
set lNullObj NULL
set pPage [GetActivePage]
set lWiresToDel [list]
set lWireIter [$pPage NewWiresIter $lStatus]
set lWireInst [$lWireIter NextWire $lStatus]
while {$lWireInst!=$lNullObj} {
    # screen out wire matched some criteria, then add to array for later delete
    lappend lWiresToDel $lWireInst
foreach wire $lWiresToDel {
    $pPage DeleteWire $wire
Since the actual Tcl script runs without page opened, SelectObject(x, y, boolvalue3) and Delete() function are not suit for my case.
So, what is the correct procedure to use DeleteWire(wire)?
  • fsdb
    fsdb over 5 years ago +2
    You have to reevaluate the page after the changes: catch {DboTclHelper_sEvalPage $pPage}
  • ChunChang Wu
    ChunChang Wu over 5 years ago in reply to fsdb +1
    Great thanks for the answer, and It solves the problems! There is poor of documents about the definition of DboTclHelper_sEvalPage . Glad you found this API!
  • fsdb
    0 fsdb over 5 years ago
    • Vote Up +2 Vote Down
  • ChunChang Wu
    0 ChunChang Wu over 5 years ago in reply to fsdb
    There is poor of documents about the definition of DboTclHelper_sEvalPage. Glad you found this API!
