  2. Allegro X Scripting - TCL
  3. OrCAD capture TCL script to find pin names of a compone...
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 16
  • Views 14528
OrCAD capture TCL script to find pin names of a component
Usman Mehmood
Usman Mehmood over 4 years ago
I want to print pin names of a component using a TCL script in OrCad capture. I used the TCL reference document provided by cadence, and this is what the code looks like.
#? Iterate over all pins of a part instance / drawn instance
set lIter [$lInst NewPinsIter $lStatus]
set lNullObj NULL
# get the first pin of the part
set lPin [$lIter NextPin $lStatus]
while {$lPin !=$lNullObj } {
    #! placeholder: do your processing on $lPin
    set lPinName [DboTclHelper_sMakeCString]
    $lPin GetName $lPinName
    set lPinName_name [DboTclHelper_sGetConstCharPtr $lPinName]
    puts "   Pin:\t\"$lPinName_name\"\t\"$lPinName\"\t\"$lPin\""
    # get the next pin of the part
delete_DboPartInstPinsIter $lIter
So there are three variables, lPinName_name, lPinName, and lPin. None of them return anything useful, instead returning strange character sequences. Am I missing something or doing something wrong here?
Any help regarding this would be highly appreciated.
  • krzysztofd
    krzysztofd over 4 years ago +2 suggested
    Assuming, that the lInst in your example holds a pointer acquired from calling the NextPartInst method and lStatus holds a pointer acquired from calling the DboState method and, if the pin names or pin…
  • krzysztofd
    krzysztofd over 3 years ago in reply to KVN +2
    # relating to the variables from the previous example: set pinTypeText {} switch [$portInst GetPinType $lStatus] $::DBO_IN { set pinTypeText IN } $::IO { set pinTypeText IO } $::DBO_OUT { set pinTypeText…
  • krzysztofd
    # you'll need both starting point and the hotspot set lStartPoint [$portInst GetStartPoint $lStatus] set lStartPointX [DboTclHelper_sGetCPointX $lStartPoint] set lStartPointY [DboTclHelper_sGetCPointY…
  • KVN
    0 KVN over 3 years ago in reply to krzysztofd
    Thanks Slight smile
  • KVN
    Thanks Slight smile
    The location are relative.. those are not exact location in the schematic, right?
    How to get exact location of the pins in the schematic..?
