  2. Allegro X Scripting - TCL
  3. OrCAD capture TCL script to find pin names of a compone...
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 16
  • Views 14527
OrCAD capture TCL script to find pin names of a component
Usman Mehmood
Usman Mehmood over 4 years ago
I want to print pin names of a component using a TCL script in OrCad capture. I used the TCL reference document provided by cadence, and this is what the code looks like.
#? Iterate over all pins of a part instance / drawn instance
set lIter [$lInst NewPinsIter $lStatus]
set lNullObj NULL
# get the first pin of the part
set lPin [$lIter NextPin $lStatus]
while {$lPin !=$lNullObj } {
    #! placeholder: do your processing on $lPin
    set lPinName [DboTclHelper_sMakeCString]
    $lPin GetName $lPinName
    set lPinName_name [DboTclHelper_sGetConstCharPtr $lPinName]
    puts "   Pin:\t\"$lPinName_name\"\t\"$lPinName\"\t\"$lPin\""
    # get the next pin of the part
delete_DboPartInstPinsIter $lIter
So there are three variables, lPinName_name, lPinName, and lPin. None of them return anything useful, instead returning strange character sequences. Am I missing something or doing something wrong here?
Any help regarding this would be highly appreciated.
  • krzysztofd
    krzysztofd over 4 years ago +2 suggested
    Assuming, that the lInst in your example holds a pointer acquired from calling the NextPartInst method and lStatus holds a pointer acquired from calling the DboState method and, if the pin names or pin…
  • krzysztofd
    krzysztofd over 3 years ago in reply to KVN +2
    # relating to the variables from the previous example: set pinTypeText {} switch [$portInst GetPinType $lStatus] $::DBO_IN { set pinTypeText IN } $::IO { set pinTypeText IO } $::DBO_OUT { set pinTypeText…
  • krzysztofd
    # you'll need both starting point and the hotspot set lStartPoint [$portInst GetStartPoint $lStatus] set lStartPointX [DboTclHelper_sGetCPointX $lStartPoint] set lStartPointY [DboTclHelper_sGetCPointY…
  • krzysztofd
    0 krzysztofd over 4 years ago
    and, if the pin names or pin numbers are all you are after, then for example:
    set result [list]
    set count [$lInst GetPinCount $lStatus]
    for {set index 0} {$index < $count} {incr index} {
        set portInst [$lInst GetPin $index $lStatus]
        set pName [DboTclHelper_sMakeCString];
        set pNumber [DboTclHelper_sMakeCString];
        $portInst GetPinName $pName;
        $portInst GetPinNumber $pNumber;
        lappend result [list [DboTclHelper_sGetConstCharPtr $pNumber] [DboTclHelper_sGetConstCharPtr $pName] ]
    puts $result
    • Vote Up +2 Vote Down
  • KVN
    0 KVN over 3 years ago in reply to krzysztofd
    How to get pin position and pin type?
    There is function "GetPinType"and "GetPinPosition"
    But how to use it to get position and type?
  • krzysztofd
    0 krzysztofd over 3 years ago in reply to KVN
    set pinTypeText {}
        set pinTypeText IN
    } $::IO {
        set pinTypeText IO
    } $::DBO_OUT {
        set pinTypeText OUT
    } $::OC {
        set pinTypeText OC
    } $::PAS {
        set pinTypeText PAS
    } $::HIZ {
        set pinTypeText HIZ
    } $::OE {
        set pinTypeText OE
    } $::POWER {
        set pinTypeText POWER
    puts $pinTypeText
    set ordinalPositionOfThePin [$portInst GetPinPosition $lStatus]; # it's just an integer
  • KVN
    Thanks for the quick reply.. How to get x and y location of the pins?
  • krzysztofd
    set lStartPointY [DboTclHelper_sGetCPointY $lStartPoint]
    set lHotSpot [$portInst GetHotSpot $lStatus]
    set lHotSpotX [DboTclHelper_sGetCPointX $lHotSpot]
    set lHotSpotY [DboTclHelper_sGetCPointY $lHotSpot]
    puts "The pin starts at ( $lStartPointX, $lStartPointY ) and connects at ( $lHotSpotX, $lHotSpotY )"
