  2. Allegro X Scripting - TCL
  3. Generate ORCAD netlist (with orWirelist.dll) using TCL ...
  • State Suggested Answer
  • Answers 1
  • Subscribers 15
  • Views 5986
Generate ORCAD netlist (with orWirelist.dll) using TCL Script
Shanmugi
Shanmugi over 4 years ago
I need to generate netlist with orWirelist.dll (as if from the 'other' tab in OrCAD) from orcad using TCL script.
I manually generated the script from tools->create netlist->other option -> orWirelist.dll (under formatters option).
But trying to generate the same using TCL scripts.
Is there a way to do, if so kindly help me on the same.
Thanks for your help in advance!
  • TechnoBobby
    TechnoBobby 5 months ago in reply to CA20240926987 +1 suggested
    Hi CA20240926987 , If you're looking to export similar format data using TCL script, you can try below code. Hope this helps! proc pinConnectivityReport {} { if {[file exists "pinConnectivity.txt"] …
  • CA20240926987
    0 CA20240926987 5 months ago
    Did you ever figure this out? I am trying to solve this problem as well.
  • TechnoBobby
    0 TechnoBobby 5 months ago in reply to CA20240926987
    Hi CA20240926987 ,
    Hope this helps!
    if {[file exists "pinConnectivity.txt"] == 1} {
    file delete "pinConnectivity.txt"
    set lPathCS [DboTclHelper_sMakeCString]
    [GetActivePMDesign] GetName $lPathCS
    set lPath [file dirname [DboTclHelper_sGetConstCharPtr $lPathCS]]
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lNullObj NULL
    set lStatus [DboState]
    set lDesign [$lSession GetActiveDesign]
    if {$lDesign == $lNullObj} {
    puts "ERROR: No active design."
    return
    set lSchi_Name [DboTclHelper_sMakeCString]
    set lPinNameCS [DboTclHelper_sMakeCString]
    set lPinNumberCS [DboTclHelper_sMakeCString]
    set lNetNameCS [DboTclHelper_sMakeCString]
    set lRefdesNameCS [DboTclHelper_sMakeCString]
    set lReport [open "pinConnectivity.txt" a+]
    if {$lDesign != $lNullObj} {
    set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
    #get the first schematic view
    set lView [$lSchematicIter NextView $lStatus]
    set lPage_Name [DboTclHelper_sMakeCString]
    while { $lView != $lNullObj} {
    #dynamic cast from DboView to DboSchematic
    set lSchematic [DboViewToDboSchematic $lView]
    $lSchematic GetName $lSchi_Name
    set lPagesIter [$lSchematic NewPagesIter $lStatus]
    #get the first page
    set lPage [$lPagesIter NextPage $lStatus]
    # puts [DboTclHelper_sGetConstCharPtr $lSchi_Name]
    while {$lPage!=$lNullObj} {
    #placeholder: do your processing on $lPage
    $lPage GetName $lPage_Name
    # puts [DboTclHelper_sGetConstCharPtr $lPage_Name]
    set lPageName [DboTclHelper_sGetConstCharPtr $lPage_Name]
    set lPartInstIter [$lPage NewPartInstsIter $lStatus]
    set lInst [$lPartInstIter NextPartInst $lStatus]
    while {$lInst != $lNullObj} {
    puts $lReport "++++++++++===========+++++++++++++"
    $lInst GetReferenceDesignator $lRefdesNameCS
    set lRefdes [DboTclHelper_sGetConstCharPtr $lRefdesNameCS]
    set lPinIter [$lInst NewPinsIter $lStatus]
    set lPin [$lPinIter NextPin $lStatus]
    while {$lPin !=$lNullObj } {
    # puts $lPin
    $lPin GetPinName $lPinNameCS
    set lPinName [DboTclHelper_sGetConstCharPtr $lPinNameCS]
    # puts "$lPinName pinName"
    $lPin GetPinNumber $lPinNumberCS
    set lPinNumber [DboTclHelper_sGetConstCharPtr $lPinNumberCS]
    # puts "$lPinNumber pinNumber"
    set lWire [$lPin GetNet $lStatus]
    # puts $lWire
    if {$lWire != $lNullObj} {
    $lWire GetNetName $lNetNameCS
    set lNetName [DboTclHelper_sGetConstCharPtr $lNetNameCS]
    # puts "$lRefdes.$lPinNumber.$lNetName.$lPageName"
    puts $lReport "$lRefdes.$lPinNumber.$lPinName.$lNetName.$lPageName"
    # puts [DboTclHelper_sGetConstCharPtr $lNetNameCS]
    #get the next pin of the part
    delete_DboPartInstPinsIter $lPinIter
    delete_DboPagePartInstsIter $lPartInstIter
    #get the next page
    #get the next schematic view
    delete_DboSchematicPagesIter $lPagesIter
    delete_DboLibViewsIter $lSchematicIter
    close $lReport
    exec {*}[auto_execok start] "" "$lPath\\pinConnectivity.txt"
