  2. Allegro X Scripting - TCL
  3. Change Variant View using TCL
  • State Suggested Answer
  • Answers 1
  • Subscribers 17
  • Views 5319
akehlenbeck
akehlenbeck over 3 years ago
Is there a way to use a TCL script to change which Variant is currently being viewed?
i.e. is there a TCL way to mimic "Shift+M, then selecting a different Variant"?
  • AyushD
    AyushD over 3 years ago +1 suggested
    If you are looking for switching variant view mode using TCL, try using below command Menu "View::Variant View Mode" | DialogBox "OK" After the "OK" a path to xml file has to be provided which lists the…
  • AyushD
    0 AyushD over 3 years ago
    After the "OK" a path to xml file has to be provided which lists the variant to be displayed
    For e.g. Menu "View::Variant View Mode" | DialogBox "OK" "C:/tmp/CAPTURELOG/Mon_May__2_11_35_26_2022/Select a Design Variant_1.xml"
  • Krissn
    0 Krissn over 2 years ago in reply to AyushD
    but .xml has a fixed variant names. So if you load another design this will not work as variants has different names!
  • CadAP
    0 CadAP over 2 years ago in reply to Krissn
    HI Krissn,
    You can use the below code to switch to variant mode.
    Please source the below code and open the design and type below command(after sourcing the tcl code)
    displayVariant {Variantname}
    For example you have variant name test1 type like below:
    displayVariant {test1}
    After successful running of code, test1 variant mode will be activated.
    proc displayVariant {Variantname} {
    set tempfile [open "temp.xml" w+]
    puts $tempfile {<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
    <DialogControls>
    <Control Type="LIST_BOX" Enable="TRUE" Visible="TRUE" Id="1265">}
    puts $tempfile " <Value><!\[CDATA\[$Variantname\]\]></Value>"
    puts $tempfile { <Value><![CDATA[<Core Design>]]></Value>
    <Value><![CDATA[TB1]]></Value>
    <Value><![CDATA[TB2]]></Value>
    </Control>
    <Control Type="PUSH_BUTTON" Enable="TRUE" Visible="TRUE" Id="1">
    <Value><![CDATA[OK]]></Value>
    </Control>
    <Control Type="PUSH_BUTTON" Enable="TRUE" Visible="TRUE" Id="2">
    <Value><![CDATA[Cancel]]></Value>
    </Control>
    <Control Type="PUSH_BUTTON" Enable="TRUE" Visible="TRUE" Id="57670">
    <Value><![CDATA[Help]]></Value>
    </Control>
    </DialogControls>}
    close $tempfile
    Menu "View::Variant View Mode" | DialogBox "OK" "[pwd]/temp.xml"
    catch {file delete "temp.xml"}
  • PatEscher
    0 PatEscher over 2 years ago in reply to CadAP
    what is the MenuCommand for "View::Variant View Mode". we will run in different UI languages, so I am wondering if it would work when e.g. running in Chinese UI using "View::Variant View Mode"
