  2. Allegro X Scripting - TCL
  3. SysCap - "Swap" Net Name"
  • State Verified Answer
  • Replies 19
  • Subscribers 16
  • Views 19041
JohnFr38
JohnFr38 over 3 years ago
Hi Everyone,
I'm having a problem using SysCapture. I would like to swap "net name" of a FPGA
On VHD designer -> Texte/swap
On SysCap -> Swap PIN
But the function modifies the PIN name and not the associated NET.
  • CadAP
    CadAP over 3 years ago in reply to JohnFr38 +4 verified
    Thanks for reply JohnFr38 #I have made little changes to the code. Please copy the below tcl code. You have to select pins of components whose nets need to be interchanged. #Please follow below steps…
  • CadAP
    CadAP over 3 years ago in reply to JohnFr38 +2 verified
    #After sourcing the below tcl code "CustomMenu" will be added and active till the System Capture is open. If you closed the system capture then you need to source the tcl file again. See the below attached…
  • srish09
    srish09 over 3 years ago +1
    Hello John, Are you swapping the pins in pcb editor and then importing the layout into System Capture? As per the flow, pins within the same pin group can be swapped in pcb editor. These changes can…
  • MZ20250602835
    0 MZ20250602835 9 months ago in reply to CadAP
    Dear CadAP,
    many thanks again.
    Best Regards
    Moyan
  • MZ20250602835
    Dear CadAp,
    may a ask you a additional question and how can pin swap between two different sections in system capture? i got error" Selected pin does not belong to same instance". With the same lib there is no problem in DE HDL.
    Best Regards
    Moyan
  • CadAP
    0 CadAP 9 months ago in reply to MZ20250602835
    MZ20250602835
    Please follow the steps mentioned in the below article:
    Article (11189588) Title: How can I swap between pins distributed across multiple slots?
    URL: support.cadence.com/.../ArticleAttachmentPortal
  • MZ20250602835
    Dear CadAp,
    many thanks for your reply. I already checked with this article. If i backward from PCB Layout to System Capture schema there is problem if the pins swapped across multiple slots in Layout.
    Also if you use the swap function direkt in the schema it is not possible to swap the pins across sections.
    Best Regards
    Moyan
