  2. Allegro X Scripting - TCL
  3. SysCap - "Swap" Net Name"
  • State Verified Answer
  • Replies 19
  • Subscribers 16
  • Views 19036
JohnFr38
JohnFr38 over 3 years ago
Hi Everyone,
I'm having a problem using SysCapture. I would like to swap "net name" of a FPGA
On VHD designer -> Texte/swap
On SysCap -> Swap PIN
But the function modifies the PIN name and not the associated NET.
  • CadAP
    CadAP over 3 years ago in reply to JohnFr38 +4 verified
    Thanks for reply JohnFr38 #I have made little changes to the code. Please copy the below tcl code. You have to select pins of components whose nets need to be interchanged. #Please follow below steps…
  • CadAP
    CadAP over 3 years ago in reply to JohnFr38 +2 verified
    #After sourcing the below tcl code "CustomMenu" will be added and active till the System Capture is open. If you closed the system capture then you need to source the tcl file again. See the below attached…
  • srish09
    srish09 over 3 years ago +1
    Hello John, Are you swapping the pins in pcb editor and then importing the layout into System Capture? As per the flow, pins within the same pin group can be swapped in pcb editor. These changes can…
  • CadAP
    0 CadAP 10 months ago in reply to MZ20250602835
    MZ20250602835
    Currently only Pin Number is editable on schematic canvas.
  • MZ20250602835
    0 MZ20250602835 9 months ago in reply to CadAP
    Dear CadAP,
    many thanks for your reply. I created another case for this issue: (1) Pin Swap issue from DE HDL to System Capture - Allegro X System Capture (EE Cockpit) - PCB Design & IC Packaging (Allegro X) - Cadence Community
    If a solution such as tcl available may i ask you to advise me in the case above?
    Many thanks again and wish you a nice day.
    Best Regards
    Moyan
  • MZ20250602835
    Dear CadAP,
    an update: i swapped the pins in PCB Editor and back annotated in System Capture, the design swap information gets updated on the schematic only the pin numbers were interchanged and the pin text wasn't changed.
  • MZ20250602835
    Dear CadAP,
    kindly to give a update and the solution is below:
    ALLOW_PINTEXT_SWAP
    By default, pin swaps received from back-end or performed on the schematic swap only pin numbers assigned to the pins. When this directive set to ON, both pin names and pin numbers assigned to the pins are swapped.
    Syntax
    ALLOW_PINTEXT_SWAP 'ON|OFF'
    Example
    ALLOW_PINTEXT_SWAP 'ON'
    Corresponding UI Option
    None
  • CadAP
    0 CadAP 9 months ago in reply to MZ20250602835
    MZ20250602835
    When you swap a pin name and number in the PCB editor and then backannotate the changes to Allegro System Capture, it is necessary to include the above directive in Allegro System Capture either site.cpm or project.cpm.
    This directive allows the pin swap to be applied to the corresponding component within Allegro System Capture.
    The pin text can also be swapped along with the pin number after defining the ALLOW_PINTEXT_SWAP directive in the START_CANVAS section of the project or site cpm.
