  2. Allegro X Scripting - TCL
  3. Capture quit unexpectedly after delete DboGlobal instances...
  • State Verified Answer
  • Subscribers 14
  • Views 3008
Capture quit unexpectedly after delete DboGlobal instances in page by TCL script DeleteGlobal
seanhung365
seanhung365 over 3 years ago
I tried using TCL to delete some DboGlobal instances which matches a criteria.
However, after I delete it by DboPage function DboGlobal, the schematic seems to have some invisible error which will lead Capture quit unexpectedly under some operations.
set lStatus [DboState]
set lNullObj NULL
set pPage [GetActivePage]
set lGlobalsToDel [list]
set lGlobalIter [$pPage NewGlobalsIter $lStatus]
set lGlobalInst [$lGlobalIter NextGlobal $lStatus]
while {$lGlobalInst!=$lNullObj} {
# screen out wire matched some criteria, then add to array for later delete
lappend lGlobalsToDel $lGlobalInst
delete_DboPageGlobalsIter $lGlobalIter
foreach lGlobal $lGlobalsToDel {
$pPage DeleteGlobal $lGlobal
#catch {DboTclHelper_sEvalPage $pPage}
#catch {ZoomRedraw}
Source File
Error
  • CadAP
    CadAP over 3 years ago +2 verified
    Hi @Seanhung365, Please find the below modifed tcl which will delete the global object form the active page. I added the below line: # 1.set GlobalItemId [$lGlobalInst GetId $lStatus] # 2.SelectObjectById…
  • CadAP
    +1 CadAP over 3 years ago
    Hi @Seanhung365,
    # 2.SelectObjectById $lGlobal
    # 3.Menu "Edit::Delete"
    # 4.Menu "File::Save"
    set lNullObj NULL
    lappend lGlobalsToDel $GlobalItemId
    UnSelectAll
    # $pPage DeleteGlobal $lGlobal
    # catch {DboTclHelper_sEvalPage $pPage}
    # catch {ZoomRedraw}
    Menu "Edit::Delete"
    Menu "File::Save"
    # Hope this helps
    • Vote Up +2 Vote Down
