  2. Allegro X Scripting - TCL
  3. OrCAD Capture CIS: Export BOM via TCL
  • State Suggested Answer
  • Answers 1
  • Subscribers 14
  • Views 7549
ggeorgg
ggeorgg over 3 years ago
I want to get the BOM for one or multiple CIS variants via TCL to be able to push it to SAP directly from OrCAD.
I found the "CVariant_GetPartsFromAllVariants" method, but I need some assistance on how I can loop over all its elements. Here is what I have already tried:
set DboDesign [GetActivePMDesign]
set CISDesign [CPartMgmt_GetCisDesign $DboDesign]
set CVariantGroupsContainer [CISDesign_GetGroupsContainer $CISDesign]
set QUIntArrayPartsFromAllVariants [QUIntArray]
set int [CVariant_GetPartsFromAllVariants $CVariantGroupsContainer $QUIntArrayPartsFromAllVariants]
set QUIntArrayUpperBound [QUIntArray_GetUpperBound $QUIntArrayPartsFromAllVariants]
set UInt [QUIntArray_GetAt $QUIntArrayPartsFromAllVariants $QUIntArrayUpperBound]
set UInt [QUIntArray_ElementAt $QUIntArrayPartsFromAllVariants $QUIntArrayUpperBound]
CISTclHelper_sGetIntFromUINT $UInt
It seems the last command returns the OccID of the "last" part in the design. Now I would like to iterate over all elements in $QUIntArrayPartsFromAllVariants, but I need to somehow create an INT_PTR manually. How can I do that?
Similar problem with the method "CNewBOm_GetAllParts"
set BOMVariantContainer [CISDesign_GetBOMVariantContainer $CISDesign]
set QUIntArrayAllParts [QUIntArray]
set int [CNewBOm_GetAllParts $BOMVariantContainer $QUIntArrayAllParts]
set QUIntArrayUpperBound [QUIntArray_GetUpperBound $QUIntArrayAllParts]
set UInt [QUIntArray_GetAt $QUIntArrayAllParts $QUIntArrayUpperBound]
set UInt [QUIntArray_ElementAt $QUIntArrayAllParts $QUIntArrayUpperBound]
So the question is, how can I iterate a QUIntArray? Or is there currently no way to iterate those type of arrays and I have to use a different method? Which one would be suited/best?
  • CadAP
    CadAP over 3 years ago +2 suggested
    #Hi ggeorgg, I have created a sample tcl which will dump all variant name with component refdes under that variant in a DumpVaraintBom.txt file at current active project. You can modify to add more information…
  • ggeorgg
    ggeorgg over 3 years ago in reply to CadAP +1
    Thanks, the code is working as expected, but what about catching errors? What happens if a user forgot to assign all components/groups to a variant? Is it possible to check this as well? I guess it is…
  • CadAP
    CadAP over 3 years ago in reply to ggeorgg +1
    Hi ggeorgg, To compare the parts: 1.GetAllParts from GetBOMVariantContainer 2.GetPartsFromGroup(each group) from GetGroupsContainer. To compare the groups: 1.GetBomGroups (each varaint) from GetBOMVariantContainer…
  • CadAP
    0 CadAP over 3 years ago
    #Hi ggeorgg, I have created a sample tcl which will dump all variant name with component refdes under that variant in a DumpVaraintBom.txt file at current active project. You can modify to add more information according to your requirements.
    #Please refer the tcl document present at cadence installed hierarchy <Cadence_installed_hierarchy>\tools\capture\tclscripts\OrCAD_Capture_TclTk_Extensions.pdf
    set CVariantGroupsContainer [$CISDesign GetBOMVariantContainer]
    set fp [open "DumpVaraintBom.txt" a+]
    set bomCount [$CVariantGroupsContainer GetBomCount]
    # puts $bomCount
    for {set i 0} {$i < $bomCount} {incr i} {
    set partArray [CISTclHelper_sMakeCUIntArray]
    set groupName [DboTclHelper_sMakeCString]
    $CVariantGroupsContainer GetBomName $i $groupName
    set partInt [$CVariantGroupsContainer GetPartsFromBom $groupName $partArray]
    set grName [DboTclHelper_sGetConstCharPtr $groupName]
    set arraySize [CISTclHelper_sGetCUIntArraySize $partArray]
    puts $arraySize
    puts $fp "+++++====VariantName:=$grName====+++++"
    for {set y 0} {$y <=$arraySize} {incr y} {
    set lPartId [CISTclHelper_sGetUInt $partArray $y]
    if {$lPartId != 0} {
    set lUINTPartId [CISTclHelper_sGetUINTFromInt $lPartId]
    # puts $lUINTPartId
    set lCISInstOcc [$CISDesign GetPartOccForID $lUINTPartId]
    # puts $lCISInstOcc
    if {$lCISInstOcc != "NULL"} {
    set lRefDes [$lCISInstOcc GetPartRefDes]
    set lRefDes [$lRefDes GetRefDes]
    set lRefDes [DboTclHelper_sMakeCString $lRefDes]
    set lRefDesStr [DboTclHelper_sGetConstCharPtr $lRefDes]
    puts $fp "$lRefDesStr"
    close $fp
    Hope this helps!
    • Vote Up +2 Vote Down
  • ggeorgg
    0 ggeorgg over 3 years ago in reply to CadAP
    What happens if a user forgot to assign all components/groups to a variant? Is it possible to check this as well? I guess it is possible with the method "GetAmbiIds". Have you already used it?
    Or what happens if a user accidentially assigns a reference designator which is already present in the design manually to a component and forgets to check it again. Is it sufficient to create a list of already written RefDes and to compare if a new RefDes is already present in the list of RefDes?
  • CadAP
    0 CadAP over 3 years ago in reply to ggeorgg
    Hi ggeorgg,
    1.GetBomGroups (each varaint) from GetBOMVariantContainer.
    2.GetAllGroups from GetGroupsContainer.
    Ans : Please check the DRC rule  for "Report identical part reference."
  • ggeorgg
    Thanks for the hint. I tried this and yes, it can help in case the user did assign the same reference designator twice on the schematic but it does not detect errors in group/subgroup assignements in the part manager.
    I have seen users who copy part from the core (first line in part manager) to groups. Like this it is possible, that the same part is present in a variant twice. The part manager directly shows the "Ambigous: Undefined" in the "Part Status" column.
    So the question is, how can I easily check these kind of errors?
    I tried this without success:
    set CAmbiguousParts [CVariant_GetAmbiguousPartsContainer $CVariantGroupsContainer]
    set BOMName_CString [DboTclHelper_sMakeCString "Variante 3"]
    set Id 0
    CAmbiguousParts_GetPartsCount $CAmbiguousParts $BOMName_CString [CISTclHelper_sGetUINTFromInt $Id]
    Do you have further hints?
  • CadAP
    Hi ggeorge,
    #Below tcl will help you to get the list of components refdes occurrence more than once in Variant.
    #This will help you to find which refdes are repeated.
    # Similarly, you can get all the properties and values and do the comparison to get the repeated components information.
    #Section "Get all the prop and its value for an lCISInstOcc" is commented you can uncomment and do the changes as per your need
    set propValueList {}
    set newvalueList {}
    set refdesList {}
    # set CVariantGroupsContainer [CISDesign_GetGroupsContainer $CISDesign]
    set CVariantGroupsContainer [CISDesign_GetBOMVariantContainer $CISDesign]
    # puts [$CVariantGroupsContainer GetGroupCount]
    # set groupSzie [$CVariantGroupsContainer GetGroupCount]
    # puts $groupSzie
    # puts "[CISTclHelper_sGetCUIntArraySize $QUIntArrayPartsFromAllVariants]"
    set int [ $CVariantGroupsContainer GetAllParts $QUIntArrayPartsFromAllVariants]
    set QuitArraySize [CISTclHelper_sGetCUIntArraySize $QUIntArrayPartsFromAllVariants]
    set partProps [CISTclHelper_sMakeCPartProp]
    set propName [DboTclHelper_sMakeCString]
    set propValue [DboTclHelper_sMakeCString]
    # puts $QuitArraySize
    for {set z 0} {$z < $QuitArraySize} {incr z} {
    # set QUIntArrayUpperBound [QUIntArray_GetUpperBound $QUIntArrayPartsFromAllVariants]
    set partIntId [CISTclHelper_sGetUInt $QUIntArrayPartsFromAllVariants $z]
    if {$partIntId != 0} {
    set lUINTPartId [CISTclHelper_sGetUINTFromInt $partIntId]
    # puts $lUINTPartId
    # puts $lCISInstOcc
    set allPartProps [$lCISInstOcc GetPartProps $partProps]
    # set allPartPropsValue [$lCISInstOcc GetPropContents $partProps]
    set partPropName [$partProps GetPropNames]
    set CStringArraySize [CISTclHelper_sGetCStringArraySize $partPropName]
    #Get all the variant prop and it value for an lCISInstOcc
    # for {set x 0} {$x < $CStringArraySize} {incr x} {
    # set propCStringName [CISTclHelper_sGetCString $partPropName $x]
    # set propCstringValue [$partProps GetPropContents $propCStringName]
    # set propName [DboTclHelper_sGetConstCharPtr $propCStringName]
    # set propValue [DboTclHelper_sGetConstCharPtr $propCstringValue]
    # lappend propValueList $propValue
    # puts "$propName:= $propValue"
    set lRefDes [DboTclHelper_sMakeCString ]
    # puts $lRefDes
    # puts $fp "$lRefDesStr"
    # puts "$lRefDesStr"
    lappend refdesList $lRefDesStr
    # puts $refdesList
    for {set x 0} {$x<[llength $refdesList]} {incr x} {
    set lsearchRefDes [lsearch $newvalueList [lindex $refdesList $x]]
    if { $lsearchRefDes < 0} {
    lappend newvalueList [lindex $refdesList $x]
    # puts "[lindex $refdesList $x] is "
    } else {puts "[lindex $refdesList $x] is present morethan once"}
